1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PyEpics timeout behavior
Date: Tue, 30 Aug 2016 14:43:21 +0000
I’m experiencing unexpected timeout behavior on PyEpics 3.2.4.
Using epics.PV, I experience double the expected timeout in all cases.
Using epics.caget(), the timeout value seems to be ignored and I
experience 5 seconds of delay when I ask for less than 5 seconds.  With
epics.caget(), if I ask for more than 5 seconds of timeout, it works as
expected.
Here is a simple Python test case to reproduce:
  import epics, time
  waittime = 2
  print "PyEpics %s test with timeout of %d seconds" %
(epics.__version__,waittime)
  print "Test 1: using epics.PV"
  time1 = time.time()
  p = epics.PV("idontexist", connection_timeout=waittime)
  time2 = time.time()
  print "  Time to create non-existent PV= ",time2-time1
  val = p.get(timeout=waittime, use_monitor=False)
  time3 = time.time()
  print "  Time to get non-existent PV= ",time3-time2
  print ""
  print "Test 2: using epics.caget"
  time1 = time.time()
  val = epics.caget("idontexist", timeout=waittime, use_monitor=False)
  time2 = time.time()
  print "  Time to caget non-existent PV= ", time2-time1
Re: [UNTRUSTED] PyEpics timeout behavior Kasemir, Kay
Re: PyEpics timeout behavior Matt Newville
Prev: ipmiComm 3.0.2 Hinxx
Next: Re: [UNTRUSTED] PyEpics timeout behavior Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
