1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
To: Kevin Peterson <[email protected]>, Benjamin Franksen <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Wed, 7 Sep 2016 14:53:07 -0500
On 09/07/2016 02:46 PM, Kevin Peterson wrote:
> That change doesn't eliminate the build error:
> "Installing created executable ../../../bin/windows-x64-static/snc.exe"
> ../Makefile:59: PATH_FILTER is deprecated; used for
> ../../../bin/windows-x64-static/lemon.exe
> ../../../bin/windows-x64-static/lemon.exe o=. -g ../snl.lem > snl.bnf.tmp
> '..' is not recognized as an internal or external command,
> operable program or batch file.
> ../Makefile:59: recipe for target '../O.Common/snl.bnf' failed
>> $(COMMON_DIR)/snl.bnf: snl.lem
>> 	$(LEMON) o=. -g $< > $(@F).tmp
>> 	$(MV) $(@F).tmp $@
The problem is that the Windows command shell doesn't like relative
paths to executables, unless they use backwards slashes. Try replacing
$(LEMON) with $(abspath $(LEMON)) to see if that helps.
- Andrew
Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
Prev: Re: github hides accounts Kevin Peterson
Next: RE: github hides accounts Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
Next: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
ANJ, 07 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
