1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
Date: Wed, 7 Sep 2016 22:50:42 +0200
Dear Mark,
Thank you very much for your support. Yes you are totally right, I put first in the PATH, the path to the Microsoft LINK command, but It didn't work. Anyway, I have tried to do what Enbregtson said, and Another compiling/linking problems have appeared. I am going to try to understand what is the new problem, and in both cases: I fix the problem or not I will write the solution or the problem :D.
Thank you very much to all
Regards
2016-09-07 21:39 GMT+02:00 Mark Rivers <[email protected]>:
I think you are confusing 2 things:
-          Using gnumake from MinGW, but using the Microsoft Visual Studio compiler and linker.  EPICS_HOST_ARCH=windows-x64 uses the Microsoft compiler and linker.
-          Using the mingw (GNU) compiler and linker.  EPICS_HOST_ARCH=windows-x64-mingw uses the GNU compiler and linker.
If you want to use the Microsoft compiler then you need to make sure that the minGW linker does not come first in your PATH, which seems like what is happening.  You can probably change your PATH definition so the Microsoft compiler tools come before the minGW tools.
From: [email protected] [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Max Power
Sent: Wednesday, September 07, 2016 2:26 PM
To: [email protected]
Subject: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2
Dear guys,
I have tried to install EPICS base 3.15.4 in windows 8.1 64 bits using MinGW tools, following instructions in EPICS.org: http://www.aps.anl.gov/epics/base/win32.php and Mark River explanation.
I have used the last version of Visual studio 2015 and all the building tools required.
After "make" command execution, everything looked going on perfect until the point the installation has used the "link" command (see below). It says that "link" command does not understand -n option. I have checked that the link.exe command installed with VC2015 has the possibility of using that argument, but the link command from MinGW GNU tools cannot. Any idea or someone with the same problem?
Thank you very much in advance!, console outputs coming below
link -nologo  -LTCG -incremental:no -opt:ref -release -version:3.15 /MACHINE:X64
              -out:antelope.exe       epicsTempFile.obj closure.obj error.obj la
lr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.
obj verbose.obj warshall.obj
Try `link --help' for more information.
make[3]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/s
rc/libCom/O.windows-x64'
make[2]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/c/Users/Max/AppData/Roaming/SPB_Data/epics/base/s
rc'
make: *** [src.install] Error 2
link version that the make uses:
$ link
link: missing operand
$ link --version
link (GNU coreutils) 5.97
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software.  You may redistribute copies of it under the terms of
the GNU General Public License <http://www.gnu.org/licenses/gpl.html>.
There is NO WARRANTY, to the extent permitted by law.
Written by Michael Stone.
$ link --help
Usage: link FILE1 FILE2
  or:  link OPTION
Call the link function to create a link named FILE2 to an existing FILE1.
      --help     display this help and exit
      --version  output version information and exit
Report bugs to <[email protected]>.
Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Ralph Lange
link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
Prev: Re: Autosave ignores PVs starting with some characters Andrew Johnson
Next: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
