On 07/09/2016 22:50, Max Power wrote:
Thank you very much for your support. Yes you are totally right, I put
first in the PATH, the path to the Microsoft LINK command, but It
didn't work. Anyway, I have tried to do what Enbregtson said, and
Another compiling/linking problems have appeared. I am going to try to
understand what is the new problem, and in both cases: I fix the
problem or not I will write the solution or the problem :D.
Usually, it is sufficient to leave the Visual Studio environment
settings as they have been set by the vcvarsall.bat script, and just
call the top level make from MinGW using its full path (e.g.
"C:\MinGW\bin\mingw32-make distclean all").
Cheers,
~Ralph
- link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
- RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
- Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Max Power
VDCT Paramveer Jain
<2016>
2025
2026
<2016>
2025
2026
ANJ, 16 Sep 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
