1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VDCT
To: [email protected]
Date: Thu, 8 Sep 2016 05:50:43 -0400
I installed VDCT with jar
when I make new record its giving some error msgs as VisualDCT console
Am I missing something??
please help
thank you in advance
Loading VisualDCT v2.6 build 1274...
--------- UNCAUGHT EXCEPTION ---------
java.lang.NullPointerException
    at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source)
    at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source)
    at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source)
    at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source)
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
    at java.awt.Component.processMouseEvent(Component.java:6516)
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
    at java.awt.Component.processEvent(Component.java:6281)
    at java.awt.Container.processEvent(Container.java:2229)
    at java.awt.Component.dispatchEventImpl(Component.java:4872)
    at java.awt.Container.dispatchEventImpl(Container.java:2287)
    at java.awt.Component.dispatchEvent(Component.java:4698)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
    at java.awt.Container.dispatchEventImpl(Container.java:2273)
    at java.awt.Window.dispatchEventImpl(Window.java:2719)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
    at java.awt.EventQueue.access$300(EventQueue.java:103)
    at java.awt.EventQueue$3.run(EventQueue.java:706)
    at java.awt.EventQueue$3.run(EventQueue.java:704)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
    at java.awt.EventQueue$4.run(EventQueue.java:720)
    at java.awt.EventQueue$4.run(EventQueue.java:718)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
    at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
    at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
    at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
    at java.awt.Dialog.show(Dialog.java:1082)
    at java.awt.Component.show(Component.java:1655)
    at java.awt.Component.setVisible(Component.java:1607)
    at java.awt.Window.setVisible(Window.java:1014)
    at java.awt.Dialog.setVisible(Dialog.java:1005)
    at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source)
    at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source)
    at com.cosylab.vdct.events.CommandManager.execute(Unknown Source)
    at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source)
    at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source)
    at java.awt.Component.processMouseEvent(Component.java:6519)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
o) Error occured while opening file '/opt/epics/base/dbd/Example2.vdb'
java.io.FileNotFoundException: /opt/epics/base/dbd/Example2.vdb (No such file or directory)
    at java.io.FileInputStream.open(Native Method)
    at java.io.FileInputStream.<init>(FileInputStream.java:146)
    at java.io.FileInputStream.<init>(FileInputStream.java:101)
    at com.cosylab.vdct.db.DBResolver.getEnhancedStreamTokenizer(Unknown Source)
    at com.cosylab.vdct.db.DBResolver.resolveIncodedDBDs(Unknown Source)
    at com.cosylab.vdct.graphics.DrawingSurface.checkForIncodedDBDs(Unknown Source)
    at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source)
    at com.cosylab.vdct.graphics.DSGUIInterface.openDB(Unknown Source)
    at com.cosylab.vdct.graphics.DsManager.openDB(Unknown Source)
    at com.cosylab.vdct.VisualDCT.openMenuItem_ActionPerformed(Unknown Source)
    at com.cosylab.vdct.VisualDCT.connEtoC7(Unknown Source)
    at com.cosylab.vdct.VisualDCT.access$900(Unknown Source)
    at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
    at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
    at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
    at com.cosylab.vdct.db.DBResolver.resolveDB(Unknown Source)
Re: VDCT Ralph Lange
Prev: Re: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Ralph Lange
Next: Re: VDCT Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 freddie.akeroyd
ANJ, 17 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
