1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Autosave ignores PVs starting with some characters
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Thu, 8 Sep 2016 13:48:43 -0500
On 09/08, Ralph Lange wrote:
> Hi Lewis,
> Please remember that in EPICS context, record and PV are not the same.
> MyRecord.SCAN is a perfectly valid PV name, containing a dot.
Hi, Ralph!
Ah, I see!  Yes, sorry about that!  Thanks!
> Chapter 6.4.11 in your AppDevGuide describes the record instance, and
> correctly mentions the allowed characters for record names.
Hmm, in the guide on the EPICS website for 3.14.12 I think it's 6.14.2,
but yes, I do see what you're talking about:
  record_name
  The record name. This must be composed of the following characters:
    a-z A-Z 0-9 _ - + : [ ] < > ;
And obviously there's no dot in that list.  Thanks for that.
Back on legal characters for a PV name, is it true that a PV name can
have no more than one dot in it (i.e. the dot separating the record name
from the field name)?
If true, then a PV name cannot start with a dot since that would mean a
zero-length record name which is illegal, right?
What about ending with a dot--can a PV name end with a dot?  Is that
interpreted as an empty field which defaults to VAL, or is a trailing
dot illegal?
Would a developer be open to a patch from me to the documentation to
further clarify the statement about legal PV name characters in section
6.3.2, Unquoted Strings, in light of the above questions?
Lewis
Re: Autosave ignores PVs starting with some characters Andrew Johnson
Autosave ignores PVs starting with some characters Konrad, Martin
RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Re: Autosave ignores PVs starting with some characters J. Lewis Muir
Re: Autosave ignores PVs starting with some characters Ralph Lange
Prev: Re: Autosave ignores PVs starting with some characters Andrew Johnson
Next: Re: Autosave ignores PVs starting with some characters Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Autosave ignores PVs starting with some characters Ralph Lange
Next: Re: Autosave ignores PVs starting with some characters Andrew Johnson
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
