1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Autosave ignores PVs starting with some characters
To: "J. Lewis Muir" <[email protected]>, Andrew Johnson <[email protected]>
Cc: [email protected]
Date: Thu, 08 Sep 2016 19:13:15 +0200
On September 8, 2016 6:45:31 PM GMT+02:00, "J. Lewis Muir" <[email protected]> wrote:
>On 09/07, Andrew Johnson wrote:
>> On 09/07/2016 03:02 PM, Mooney, Tim M. wrote:
>> > Turns out EPICS won't load a record whose name starts with '.'
>> The IOC does reject attempts to create a record whose name has any of
>> the characters space, double-quote, single-quote, dot or dollar sign
>in
>> it anywhere, not just at the beginning of the name. That is the only
>> enforced naming limitation at the moment.
>Hi, Andrew!
>It would be great if the Application Developer's Guide could be updated
>to state this.  In section 6.3.2 of the 3.14.12.5 version of the
>Application Developer's Guide ([1]) it says:
>  6.3.2 Unquoted Strings
>  In the summary section, some values are shown as quoted strings and
>  some unquoted. The actual rule is that any string consisting of only
> the following characters does not have to be quoted unless it contains
>  one of the above keywords:
>  a-z A-Z 0-9 _ - : . [ ] < > ;
>  These are also the legal characters for process variable names. Thus
>  in many cases quotes are not needed.
>As you can see, dot is clearly in the character list, and the sentence
>right below it says those characters are the legal characters for PV
>names.
>Thanks,
>Lewis
>[1]
>http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node7.html#SECTION00730000000000000000
Hi Lewis,
Please remember that in EPICS context, record and PV are not the same.
MyRecord.SCAN is a perfectly valid PV name, containing a dot.
Chapter 6.4.11 in your AppDevGuide describes the record instance, and correctly mentions the allowed characters for record names.
Cheers
~Ralph
Re: Autosave ignores PVs starting with some characters J. Lewis Muir
Autosave ignores PVs starting with some characters Konrad, Martin
RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Re: Autosave ignores PVs starting with some characters Andrew Johnson
Prev: Re: Autosave ignores PVs starting with some characters J. Lewis Muir
Next: Re: Autosave ignores PVs starting with some characters Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Autosave ignores PVs starting with some characters J. Lewis Muir
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
