1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: motor command in synApps
To: l123173 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 13 Sep 2016 14:03:08 +0000
Hi Li Xing,
Can you please send the complete output when the IOC boots.  Because you have set the asynTraceMask for port serial to 0xFF you should see the complete communication with the controller.
After the iocBoots please send the output of the command "dbior".
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Tuesday, September 13, 2016 4:49 AM
To: [email protected]
Subject: motor command in synApps
Hi all,
        I sent the question last week, did not get the answer. So I sent it again.
        I want to control the Kohzu motor with motor6-10 module in synApps.     (fedora23  synApps 5.8   motor6.10   epics 3.15.3)
        I started the IOC with the st.cmd.kohzu1(the content was following, also in attachment).
        I am sure that the configure of serial was right.
        I got the "IDN?" output when the IOC started ( I saw the output with serial tool ), so I think the IOC worked fine.
        But I do not know how to do it then. For example, I do not know how to execute the command "ORG" or any other command of Kohzu controller.
        These command are all exist in KohzuSrc file. Why I could got the IDN command, could not get the other command?
        the dbl list was associated with motor.substitutions.(IOC:m1,IOC:m2,.....,IOC:m8)
        Which step I forgot?
Li xing
st.cmd.kohzu1:
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("TOP","/opt/epics/synApps_5_8/support/motor-6-10")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("STREAM","/opt/epics/synApps_5_8/support/stream-2-6a")
epicsEnvSet("ASYN","/opt/epics/synApps_5_8/support/asyn-4-26")
epicsEnvSet("MOTOR","/opt/epics/synApps_5_8/support/motor-6-10")
# For deviocstats
# Change this PV according to set-up
# Overide default
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Register all support components
dbLoadDatabase("$(TOP)/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("motor.substitutions")   #this file in motor/ioc/ioc/ ,the content was in "dbl"
drvAsynSerialPortConfigure("serial","/dev/ttyS0",0,0,0)
asynOctetSetInputEos("serial",0,"\r\n")
asynOctetSetOutputEos("serial",0,"\r\n")
asynSetOption("serial",0,"baud","38400")
asynSetOption("serial",0,"bits","8")
asynSetOption("serial",0,"stop","1")
asynSetOption("serial",0,"parity","none")
asynSetOption("serial",0,"clocal","Y")
asynSetOption("serial",0,"crtscts","N")
asynSetOption("serial",0,"")
asynSetTraceIOMask("serial",0,2)
asynSetTraceMask("serial",0,0xFF)
SC800Setup(1,1)
# Kohzu SC-800 motor controller configuration parameters:
#     (1) controller# being configured
#     (2) ASYN port name
#     (3) address (GPIB only)
SC800Config(0,"serial",0)
var drvSC800debug 4
# Start EPICS IOC
iocInit
motor.substitutions:
file "$(MOTOR)/db/basic_motor.db"
pattern
{P,     N,  M,        DTYP,      C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{IOC:,  1,  "m$(N)",  "SC-800",  0,  0,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  2,  "m$(N)",  "SC-800",  0,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  3,  "m$(N)",  "SC-800",  0,  2,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  4,  "m$(N)",  "SC-800",  0,  3,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  5,  "m$(N)",  "SC-800",  0,  4,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  6,  "m$(N)",  "SC-800",  0,  5,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  7,  "m$(N)",  "SC-800",  0,  6,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  8,  "m$(N)",  "SC-800",  0,  7,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
motor command in synApps l123173
Prev: Test Benjamin Franksen
Next: Re: motor command in synApps Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: motor command in synApps l123173
ANJ, 13 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
