1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor command in synApps
To: l123173 <[email protected]>, <[email protected]>
Date: Tue, 13 Sep 2016 09:43:56 -0500
On 9/13/16 4:49 AM, l123173 wrote:
>         I got the "IDN?" output when the IOC started ( I saw the output
> with serial tool ), so I think the IOC worked fine.
>         But I do not know how to do it then. For example, I do not know
> how to execute the command "ORG" or any other command of Kohzu controller.
The SC-800 support prints the output of the "IDN?" command during
motor_init() using sprintf().
The "ORG" command gets sent to the controller when a "1" is written to
the motor record's HOMF or HOMR field.  This is usually done with a
channel-access client (caput, MEDM, CSS-BOY, caQtDM, EDM).  It can also
be done from the IOC's shell using the "dbpf" command:
  epics> help dbpf
  dbpf 'record name' value
  epics> dbpf IOC:m1.HOMR 1
  DBR_SHORT:          1         0x1
Kevin
motor command in synApps l123173
Prev: RE: motor command in synApps Mark Rivers
Next: Question about display history data in the form of data reports table in CSS boy opi ? lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Test Benjamin Franksen
ANJ, 14 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
