1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS Boy Write PVs to file
Date: Wed, 21 Sep 2016 18:56:04 +0000
I am running CS-Studio 4.1.1 NSLSII on Windows 7 Professional.    I am writing a GUI to interface to the IOC, using Python for the occasional scripts.  I wish to save some Process Variables to a CSV file, but I cannot figure out the code to retrieve the values from the PVs into Python.  I only want to save the data when the button is clicked, so I don’t think writing an embedded script is suit, and instead execute the script as an action.  The example program (I/O omitted) is:
from org.csstudio.opibuilder.scriptUtil import PVUtil
from java.awt import EventQueue
from javax.swing import JFrame
from javax.swing import JOptionPane
from javax.swing import JFileChooser
from jarray import zeros
from java.lang import Integer
#Force refresh of trim PVs
#This part doesn't crash
for trim_idx in range(4):
       PVUtil.writePV("iainmtestSetTR{}.PROC".format(trim_idx+1),1,10000)
trim_dac = zeros(640,Integer);
#This part runs, and values are printed
#PVUtil.createPV() requires a widget
print("About to try to create process variables")
pvs = []
for pv_idx in range(4):
       pvs.append(PVUtil.createPV("iainmtestTR{}".format(pv_idx+1), widget))
print(pvs)
#Try to retrieve the values from the PVs
#Program fails below
       trim_dac = PVUtil.getLongArray(pvs[pv_idx])
       curr_row = [];
       for chan_idx in range(640):
              curr_row.append(str(trim_dac[chan_idx]))
       print(curr_row)
The output is:
[org.csstudio.simplepv.pvmanager.PVManagerPV@6343ddb4, org.csstudio.simplepv.pvmanager.PVManagerPV@35a4c0a3, org.csstudio.simplepv.pvmanager.PVManagerPV@5a7d7484, org.csstudio.simplepv.pvmanager.PVManagerPV@2fccb8d3]
2016-09-21 14:51:16 ERROR: Error exists in script DAC Trim Save pared.py
Traceback (most recent call last):
  File "<script>", line 29, in <module>
       at org.csstudio.opibuilder.scriptUtil.PVUtil.checkPVValue(PVUtil.java:96)
       at org.csstudio.opibuilder.scriptUtil.PVUtil.getLongArray(PVUtil.java:150)
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
       at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
       at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
       at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.RuntimeException: java.lang.RuntimeException: PV iainmtestTR1 has no value.
What do I need to change to retrieve the PVs.
Thank you,
Iain.
Prev: procServ softIOC server - V2.6.1 released Ralph Lange
Next: Re: CSS Boy Write PVs to file Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 21 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
