1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using text/graphic object to block a widget
To: "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Oct 2016 18:02:43 +0000
Hi Tim,
Thanks!
I will try this out.
Yuelin
Sent: Monday, October 17, 2016 12:11 PM
To: Li, Yuelin <[email protected]>; [email protected]
Hi Yuelin,
You can control the visibility of a widget by grouping it and setting the visibility of the group.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Li, Yuelin [[email protected]]
Sent: Monday, October 17, 2016 11:42 AM
To: [email protected]
Subject: Using text/graphic object to block a widget
Dear colleagues,
It has been suggested by multiple colleagues that one can control the visibility of a text object to block the access of a widget under certain conditions. However, when I tried it turns out text/graphic objects are always behind the widgets so even when they are visible they do not block the widget. I also could not control the visibility of any of the widget. I tried it both in MEDM and in caQTDM.
Is it by design that that this function is impossible or I did it wrong?  Thanks.
Best,
Yuelin
_________________________
X-Ray Science Division
Argonne National Laboratory
Phone: 630 252 7863
Adjunct
Dynamics Compression Sector
Washington State University
Using text/graphic object to block a widget Li, Yuelin
RE: Using text/graphic object to block a widget Mooney, Tim M.
Prev: RE: Using text/graphic object to block a widget Mooney, Tim M.
Next: RE: archive engine Caizhen Liu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: MEDM wheel switch Problem PilkyuJung
ANJ, 18 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
