1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM wheel switch Problem
To: [email protected]
Date: Tue, 18 Oct 2016 19:29:10 +0900
Hello all,
This is Jung who work at BMI. and I am using MEDM 3.1.8.1.
I open New file. and when I make new Wheel Switch, I got error like this.
Tue Oct 18 19:18:41 KST 2016
xErrorHandler:
BadDrawable (invalid Pixmap or Window parameter)
xErrorHandler:
xErrorHandler:
xErrorHandler:
xErrorHandler:
xErrorHandler:
xErrorHandler:
This error is happened every controlling wheel switch. also it happened during use 3.1.9.
So, could you tell me how I can fix it?
Best Regards,
Pilkyu Jung
Re: MEDM wheel switch Problem Andrew Johnson
Prev: RE: archive engine Caizhen Liu
Next: Re: MEDM wheel switch Problem Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using text/graphic object to block a widget Li, Yuelin
ANJ, 18 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
