1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: channel connect timeout error
To: "'J. Lewis Muir'" <[email protected]>, palak shimpee <[email protected]>
Date: Thu, 20 Oct 2016 14:51:57 +0000
Please also show the output of the following command at the IOC prompt:
epicsPrtEnvParams
and the output of the following command at the shell prompt where you are running caput:
printenv | grep EPICS
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of J. Lewis Muir
Sent: Thursday, October 20, 2016 9:50 AM
To: palak shimpee
Cc: [email protected]
Subject: Re: channel connect timeout error
On 10/20, palak shimpee wrote:
> I have made a small program. CTRL-FOOO:input is a variable. When I am
> compiling and running IOCs, the IOC are running. But when i am writing
> *caput CTRL-FOOO:input 10* on terminal window it is showing error
> which is *Channel connect timed out: 'CTRL-FOOO:input' not found*
Hello, Palak.
Is it a soft IOC running on the same host on which you're running caput?
Can you provide the console output for starting the soft IOC?
Can you provide the .db file you used to define the record providing the
CTRL-FOOO:input PV?
What does "dbpf CTRL-FOOO:input 10" show when entered on the IOC's
console?
Lewis
channel connect timeout error palak shimpee
Re: channel connect timeout error J. Lewis Muir
Prev: Re: channel connect timeout error J. Lewis Muir
Next: Re: channel connect timeout error Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 20 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
