Palak,
In my understanding CSS will not serve EPICS PV's since it is an EPICS client. You should use the LabVIEW server method; your screenshot shows you are using the LabVIEW client. If you want I can send you some screen shots of our LabVIEW server configuration (we also are using the client method in another system). In that, we populate the EPICS Server1 with PV's, and associate/bind each PV with a LabVIEW network published variable. -Paul Sichta PPPL On Mon, Oct 24, 2016 at 4:19 AM, palak shimpee <[email protected]> wrote:
| ANJ, 24 Oct 2016 |
Home
News
About
Talk
Base
Modules
Extensions
