Presumably your set up is that you have 2 EPICS CA clients (Labview and CSS)
running on the same host machine connecting to a EPICS PV on the same subnet.
One connects (CSS) and the other does not (Labview).
If your EPICS PVs are really strings then Labview should probably not be using
a numeric indicator as shown in the screen shot.
Is this a CRio Labview system?
Also what is the Labview OS: vxWorks, Linux, Windows?
We have noticed here that without some modification the CRio system running
under vxWorks sends the CA request to broadcast address 255.255.255.255 by
default.
Marty
On 10/24/2016 03:19 AM, palak shimpee wrote:
I have two variables with data-type as string. The variables are
CWS-TXX-WFC:SpeedFB and CWS-TXX-WFC:SpeedSP. EPICS and LabVIEW are on same host.
In LabVIEW , I have made a project to read these variables from CSS and its
screenshots are attached. I have made these as shared variable and also done
EPICS settings in CSS. But I an unable to get the values in LabVIEW and is
showing an error.
- EPICS with LabVIEW palak shimpee
Pending synApps pull requests Henrique Almeida
mrfioc2 releases 2.0.5 and 2.1.0 Michael Davidsaver
<2016>
2025
2026
Re: EPICS with LabVIEW Paul Sichta
assert in caserverio.c Vodopivec, Klemen
<2016>
2025
2026
