On 10/31/2016 07:41 AM, "भावना नितिन मेढ़" wrote:
> Is it possible that I do not use NFS at all? I have used
> -DOMIT_NFS_SUPPORT, but still NFS is being used.
This option has been broken for some time due (I think) to rtems api
changes. I have most of a fix for this, but it's been stalled for lack
of my time (https://github.com/mdavidsaver/epics-base/commits/multiboot).
Also, the TFTP client is broken in all rtems 4.10.x releases
(https://devel.rtems.org/ticket/2375). >=4.11 doesn't work with epics
yet (Heinz is working on this).
> What is the other method to load st.cmd. In VxWorks it was pretty simple,
> just provide the path of st.cmd.
Unless you are prepared to do, or sponsor, some work the only realistic
option for RTEMS is NFSv3.
Michael
> -Bhavna
>> Another quick check of an NFS server is 'showmount -e 100.100.100.110'
>> to probe the running server. Failed mount attempts should be logged (eg
>> /var/log/syslog or similar).
>> Also, the RTEMS NFS client doesn't speak NFSv4 yet.
>> On 10/28/2016 12:05 PM, Heinz Junkes wrote:
>>> Bhavna,
>>> on host 100.100.100.110 there must be a nfs server running.
>>> Please check that host for nfs.server processes:
>>> $ ps -ef | grep nfsd
>>> rtems 5536 5516 0 18:01 pts/14 00:00:00 grep --color=auto nfsd
>>> root 19606 2 0 Aug30 ? 00:00:00 [nfsd4]
>>> root 19607 2 0 Aug30 ? 00:00:00 [nfsd4_callbacks]
>>> root 19611 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19612 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19613 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19614 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19615 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19616 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19617 2 0 Aug30 ? 00:00:00 [nfsd]
>>> root 19618 2 0 Aug30 ? 00:00:00 [nfsd]
>>> and /etc/exports
>>> that there is an entry for /tftpboot/rt_test3 like this:
>>> $ more /etc/exports
>>> # /etc/exports: the access control list for filesystems which may be
>>> exported
>>> #to NFS clients. See exports(5).
>>> /tftpboot/rt_test3 100.100.100.0/24(rw,sync,no_subtree_check)
>>> HTH,
>>> Heinz
>>> Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
>>> Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
>>> Faradayweg 4-6 |
>>> D - 14195 Berlin | E-Mail: [email protected]
>>> <mailto:[email protected]>
>>> On 28 October 2016 at 11:22:43, भावना नितिन%
- Re: Error with RTEMS on MVME5500 Michael Davidsaver
- Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Re: CA connection problems between VxWorks and Windows Michael Davidsaver
<2016>
2025
2026
<2016>
2025
2026
