On 10/31/2016 10:26 AM, Michael Davidsaver wrote:
> Unless you are prepared to do, or sponsor, some work the only realistic
> option for RTEMS is NFSv3.
I should clarify. The RTEMS NFS client speaks only version 2 over UDP,
while the Linux NFS server (which I've always used) speaks both v2, v3,
and now v4 over both UDP and TCP transports. To check which versions an
NFS server supports run:
> $ /usr/sbin/rpcinfo -p localhost|grep nfs
> 100003 2 tcp 2049 nfs
> 100003 3 tcp 2049 nfs
> 100003 4 tcp 2049 nfs
> 100003 2 udp 2049 nfs
> 100003 3 udp 2049 nfs
> 100003 4 udp 2049 nfs
The important line for RTEMS being
Of course individual mounts must still be exported in a way (host ACL)
which allows a v2/3 client to mount them.
- Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
- Re: Error with RTEMS on MVME5500 Michael Davidsaver
quadEM R7-0 now available Mark Rivers
EPICS Base Release-Candidate Double Feature! Andrew Johnson
<2016>
2025
2026
areaDetector and ADCore R2-5 released Mark Rivers
<2016>
2025
2026
