1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error to doing ./st.cmd
To: 장진수 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 8 Nov 2016 12:05:41 -0600
Hi Jinsu,
>> I successd make a IOC in a Linux OS before
>> But when i trying to build a IOC in window OS
>> It failed with this can't understand instruction words
>> Could you tell me the reason?
>> ♧ljh@JaehyungLee /usr/local/epics/test/iocBoot/io♧ctest
>> ♧$ ./st.cmd
>> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>
>> ♧#!../../bin/cygwin-x86/test
>> ♧'#!..'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
>> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
>> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>#♧# You may have to change test to something else
>> ♧'##'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
>> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
>> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>#♧# everywhere it appears in this file
>> '♧##'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
>> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
>> ♧▒▒▒ ▒▒▒▒▒▒ ▒ùٸ▒▒▒ ▒ʽ▒▒ϴ▒.
>> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>< ♧envPaths
It looks like your attempt to start the IOC is actually running the
st.cmd script using the Windows shell instead of running the IOC binary.
Windows does not understand the Unix #! line at the beginning of a
script file, although Cygwin's Bash interpreter does. Unfortunately you
are building your IOC as a Cygwin target but not using Bash as your
shell, so one simple way to solve your problem might be to start the IOC
inside a Cygwin terminal window, or to run 'bash' from the Windows
command-line. You also have to configure your PATH variable, which you
can do by sourcing the relPaths.sh file that should have been created in
your ioctest directory:
$ . relPaths.sh
$ ./st.cmd
If you want to start the IOC from the regular Windows Command shell you
have to give the name of the IOC executable as well as the startup
script filename. Your PATH variable also needs to be set properly, but
you can ask the EPICS build system to generate a batch file
(dllPath.bat) that does all that for you like the relPaths.sh file I
mentioned above which is for the Cygwin shell. Edit your
iocBoot/ioctest/Makefile and change the TARGETS = line to this:
    TARGETS = envPaths dllPath.bat
Then run 'make' in the ioctest directory, which will cause the file
dllPath.bat to be created. Running that batch file will append the
necessary directories to your PATH, and then you can start the IOC:
C:\cygwin\usr\local\epics\test\iocBoot\ioctest> dllPath.bat
C:\cygwin\usr\local\epics\test\iocBoot\ioctest> test st.cmd
- Andrew
Error to doing ./st.cmd 장진수
RE: Error to doing ./st.cmd Mark Rivers
Prev: Any EPICS Support for EcoGamma-g Gamma Detector or FHT 762 Wendi-2 Neutron Detector ? Jacob Paul DeFilippis
Next: Re: Multiple NDPluginPva issues Bruno Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Error to doing ./st.cmd Mark Rivers
Next: Vacant Position - Head of Controls & Computing - Australian Synchrotron (ANSTO) Genevieve Lobo
ANJ, 08 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
