1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error to doing ./st.cmd
To: 장진수 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 8 Nov 2016 02:31:27 +0000
> Ignore the emoticon♧
Unfortunately the emoticon is not the only problem with your message.
Basically everything after this line does not print correctly on my computer, so I cannot help you diagnose the problem.  Can you paste the error message as standard 7-bit ASCII characters?
> ♧#!../../bin/cygwin-x86/test
From: [email protected] [[email protected]] on behalf of 장진수 [[email protected]]
Sent: Monday, November 07, 2016 5:17 PM
To: [email protected]
Subject: Error to doing ./st.cmd
> Hello my name is jinsu
> I successd make a IOC in a Linux OS before
> But when i trying to build a IOC in window OS
> It failed with this can't understand instruction words
> Could you tell me the reason?
> ♧ljh@JaehyungLee /usr/local/epics/test/iocBoot/io♧ctest
> ♧$ cat st.cmd
> ♧## You may have to change test to something else
> ♧## everywhere it appears in this file
> ♧< envPaths
> ♧cd "${TOP}"
> ♧## Register all support components
> ♧dbLoadDatabase "dbd/test.dbd"
> ♧test_registerRecordDeviceDriver pdbbase
> ♧## Load record instances
> ♧dbLoadRecords("db/test.db","user=ljhHost")
> ♧cd "${TOP}/iocBoot/${IOC}"
> ♧iocInit
> ♧## Start any sequence programs
> ♧#seq sncxxx,"user=ljhHost"
> ♧$ ./st.cmd
> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>
> ♧'#!..'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>#♧# You may have to change test to something else
> ♧'##'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>#♧# everywhere it appears in this file
> '♧##'▒▒(▒▒) ▒▒▒▒ ▒Ǵ▒ ▒ܺ▒ ▒▒▒, ▒▒▒▒♧▒▒ ▒▒ ▒ִ▒ ▒▒▒α׷▒, ▒Ǵ▒
> ♧▒▒ġ ▒▒▒▒▒▒ ▒ƴմϴ▒.
> ♧▒▒▒ ▒▒▒▒▒▒ ▒ùٸ▒▒▒ ▒ʽ▒▒ϴ▒.
> ♧C:\cygwin\usr\local\epics\test\iocBoot\ioctest>< ♧envPaths
[https://mail.naver.com/readReceipt/notify/?img=Wm%2BoWN3qWHbsFAKZKBF8hzE%2FMx3oFqt%2FpoM9pzKlM6F4KqM%2FpA2wKoiCFxk0pzpgMr9TM40npB%2B0Mogw74lR74lcWNFlbX30WLloWrdQaX30Mr2R%2BzJn1dICbHK5M6ln74%2BT%2B2%3D%3D.gif]
Re: Error to doing ./st.cmd Andrew Johnson
Error to doing ./st.cmd 장진수
Prev: Error to doing ./st.cmd 장진수
Next: Vacant Position - Head of Controls & Computing - Australian Synchrotron (ANSTO) Genevieve Lobo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Error to doing ./st.cmd Andrew Johnson
ANJ, 08 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
