1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Opinion on timing system for synchrotron beamlines
To: 'Márcio Paduan Donadio' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Nov 2016 00:26:37 +0000
At the APS I would say that as far as I know no beamlines rely on accurate timestamps from the accelerator timing system.   The timestamps that the beamlines are using are based on NTP timing, so are probably good to a few ms?
What the beamlines do use are hardware timing signals that allow experiments to synchronize to the ring electron bunch structure.  There is one signal that is a pulse at the ring frequency (orbital period) and another that gives a pulse for each bunch in the ring.  These are used to synchronize lasers, fast shutters, fast detectors, etc.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Márcio Paduan Donadio
Sent: Wednesday, November 09, 2016 1:27 PM
To: [email protected]
Cc: Márcio Paduan Donadio
Subject: Opinion on timing system for synchrotron beamlines
     I'd like to know your experience regarding integration of the
accelerator timing system with the beamlines:
     - Which accelerator events are useful for the beamlines' control
system.
     - Do the beamlines use a global and very precise timestamp sent
from the accelerator timing system? What is the time precision?
     - Do you think that a PTP system is sufficient for timestamping
experiments in beamlines?
     - What is the EPICS role regarding such a timing system?
     Thank you,
Engenheiro de Computação - Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron - (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
+ 55 (19) 3512-3520 - [email protected]
www.lnls.cnpem.br
RE: Opinion on timing system for synchrotron beamlines Alessandro Drago
Opinion on timing system for synchrotron beamlines Márcio Paduan Donadio
Prev: RE: motor6-10 Mooney, Tim M.
Next: Re: Packed Data Message Formats With Fixed-Length Strings Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Opinion on timing system for synchrotron beamlines Márcio Paduan Donadio
Next: RE: Opinion on timing system for synchrotron beamlines Alessandro Drago
ANJ, 11 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
