Hi Iain,
In StreamDevice you can use the variable MaxInput instead of a
terminator if you have a fixed number of input bytes.
To give more advice I would need to see a message. 'Python struct format
"128s12ii"' does not mean anything to me.
Dirk
On 08.11.2016 17:46, Iain Marcuson wrote:
I am writing EPICS code to interface with a custom device. The device protocol is fixed-length messages. I can read and write the message parameters with Stream Device, and have done so successfully except for the fixed-length string, which I have had to bypass in assorted ways.
The output command message has the Python struct format "ii128s12i". The input message has the Python struct format "128s12ii". The "12i" refers to 12 parameters, passed or returned.
My two questions are:
1) How can I parse the fixed-length string? The normal string-handling routines fail either because of terminator characters in the string or because the string is two long.
2) I handle the parameters by having a PV for each parameter, and a separate "group" of PVs for each command. Is this best practice?
Thank you,
Iain Marcuson.
- RE: Packed Data Message Formats With Fixed-Length Strings michael.abbott
- Packed Data Message Formats With Fixed-Length Strings Iain Marcuson
RE: Opinion on timing system for synchrotron beamlines Mark Rivers
<2016>
2025
2026
RE: Packed Data Message Formats With Fixed-Length Strings Iain Marcuson
<2016>
2025
2026
