1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice/AsynIPPort question
To: "[email protected] Talk" <[email protected]>
Date: Thu, 10 Nov 2016 17:30:47 -0300
We are having problems with IOC crashing when a device connected by an IP socket is unavailable.
For example, in the startup script is a line like:
drvAsynIPPortConfigure("temp", "172.16.5.218:10010")
and a StreamDevice record that uses that IP port when it calls it's protocol.
 If we unplug the ethernet cable from the device (or just power it off) the IOC crashes after a short while. No error is emitted on the console  to indicate that the connection has failed.
So, I'm wondering if there is something we need to do in setting up the AsynIPPort  or the StreamDevice protocol file in order to gracefully handle the case where the socket disappears and can't be reconnected to....
Mike Westfall
Control Systems Software Engineer
RE: StreamDevice/AsynIPPort question Mark Rivers
Prev: RE: Native NI LabVIEW/EPICS integration Mark Rivers
Next: RE: StreamDevice/AsynIPPort question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
ANJ, 07 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
