I run many IOCs on Linux that use StreamDevice to devices that are often disconnected for weeks, and the IOCs don’t crash.
What version of EPICS base, StreamDevice and asyn are you running?
On Behalf Of Michael Westfall
Sent: Thursday, November 10, 2016 2:31 PM
To: [email protected] Talk
Subject: StreamDevice/AsynIPPort question
We are having problems with IOC crashing when a device connected by an IP socket is unavailable.
For example, in the startup script is a line like:
drvAsynIPPortConfigure("temp", "172.16.5.218:10010")
and a StreamDevice record that uses that IP port when it calls it's protocol.
If we unplug the ethernet cable from the device (or just power it off) the IOC crashes after a short while. No error is emitted on the console to indicate that the connection has failed.
So, I'm wondering if there is something we need to do in setting up the AsynIPPort or the StreamDevice protocol file in order to gracefully handle the case where the socket disappears and can't be reconnected
to....
Control Systems Software Engineer
- Re: StreamDevice/AsynIPPort question Michael Westfall
- StreamDevice/AsynIPPort question Michael Westfall
RE: StreamDevice/AsynIPPort question Mark Rivers
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
<2016>
2025
2026
<2016>
2025
2026
ANJ, 11 Nov 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
