1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FLOOR function in EPICS CALC error
To: <[email protected]>
Date: Fri, 11 Nov 2016 20:08:59 +0000
I am seeing what I think may be a rounding error in the FLOOR function and I was wondering if others had seen this. I replaced the variables in my code with actual values to reproduce the problem. I am using EPICS R3.14.12.5 with Scientific Linux 7. I also tried it with the same version of EPICS running on Linux Mint
In Calc records, just using an empty Calc record and putting the values in by hand:
record(calc,"DLY:FSTEP")
 field(CALC,"6.1-0.2/0.01")
6.1-0.2/0.01 gives 590 as it should
However:
FLOOR((6.1-0.2)/0.01)
Gives me 589
If I write it as follows:
FLOOR((6.1-0.2)*(1/0.01))
I again get 590 (as it should be)
I wondered if this was my install or if this has been seen before. It only seems to happen for random values.
Best regards,
Rory Clarke
RE: FLOOR function in EPICS CALC error Mooney, Tim M.
Prev: RE: StreamDevice/AsynIPPort question Mark Rivers
Next: RE: FLOOR function in EPICS CALC error Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asyn readFloat64 not setting record value Mark Rivers
ANJ, 11 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
