Is there a way to debug where it crashes when running on RTEMS?
Sent: Friday, November 11, 2016 12:06 PM
To: Mark Rivers
Cc: [email protected] Talk
Subject: Re: StreamDevice/AsynIPPort question
We are using an RTEMS MVME-2700 target, with Asyn-4-29-1 and StreamDevice-2-6
I think it may actually be an RTEMS BSP problem, because today I ran the same test using a Linux soft IOC, and the IOC doesn't crash when the socket isn't available like it does when running the IOC on the VME target.
On Thu, Nov 10, 2016 at 6:34 PM, Mark Rivers <[email protected]> wrote:
I run many IOCs on Linux that use StreamDevice to devices that are often disconnected for weeks, and the IOCs don’t
crash.
What version of EPICS base, StreamDevice and asyn are you running?
[email protected] [mailto:[email protected]]
On Behalf Of Michael Westfall
Sent: Thursday, November 10, 2016 2:31 PM
To: [email protected] Talk
Subject: StreamDevice/AsynIPPort question
We are having problems with IOC crashing when a device connected by an IP socket is unavailable.
For example, in the startup script is a line like:
drvAsynIPPortConfigure("temp", "172.16.5.218:10010")
and a StreamDevice record that uses that IP port when it calls it's protocol.
If we unplug the ethernet cable from the device (or just power it off) the IOC crashes after a short while. No error is emitted on the console to indicate that the connection has failed.
So, I'm wondering if there is something we need to do in setting up the AsynIPPort or the StreamDevice protocol file in order to gracefully handle the case where the socket disappears
and can't be reconnected to....
Control Systems Software Engineer
- Re: StreamDevice/AsynIPPort question Michael Westfall
- StreamDevice/AsynIPPort question Michael Westfall
- RE: StreamDevice/AsynIPPort question Mark Rivers
FLOOR function in EPICS CALC error rory.clarke
<2016>
2025
2026
<2016>
2025
2026
ANJ, 17 Nov 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
