On 11/16, Wang Xiaoqiang (PSI) wrote:
> Hi Lewis,
> I just want to report my working setup of MEDM on macOS Sierra, with
> XQuartz 2.7.11.
Hi, Xiaoqiang!
Thank you for your report!
> I have installed openmotif from MacPorts
> $ port installed | grep openmotif
> openmotif @2.3.4_3 (active)
> The medm (3.1.9) extension is configured like this
> $ cat configure/os/CONFIG_SITE.darwin-x86.darwin-x86
> # DarwinPorts OpenMotif
> X11_LIB=/opt/local/lib
> X11_INC=/opt/local/include
> MOTIF_LIB=/opt/local/lib
> MOTIF_INC=/opt/local/include
> I just tried a “make clean&&make”. That still works.
I suspect that still works because your Motif library (libXm) is using
the X Toolkit Intrinsics library (libXt) from MacPorts, not the one
from XQuartz. Can you run the following command on your medm binary to
confirm?
--- 8< ---
$ otool -L ./medm
./medm:
/opt/epics-3.14.12.5/lib/darwin-x86/libca.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
/opt/epics-3.14.12.5/lib/darwin-x86/libCom.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
/opt/pkg/lib/libXm.4.dylib (compatibility version 5.0.0, current version 5.4.0)
/opt/X11/lib/libXt.6.dylib (compatibility version 7.0.0, current version 7.0.0)
/opt/X11/lib/libXmu.6.dylib (compatibility version 9.0.0, current version 9.0.0)
/opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current version 10.0.0)
/opt/X11/lib/libXext.6.dylib (compatibility version 11.0.0, current version 11.0.0)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 307.4.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1238.0.0)
--- >8 ---
As you can see, my medm is linked against /opt/X11/lib/libXt.6.dylib
which is provided by XQuartz. I suspect yours will not be linked
against that one but rather against one from MacPorts.
Looking at the MacPorts Portfile for x11/openmotif, it contains a
depends_lib entry for port:xorg-libXt which means it depends on the
x11/xorg-libXt port. It also contains this line:
require_active_variants xorg-libXt flat_namespace
I think that means you would have to specify the flat_namespace
variant for the x11/xorg-libXt port. And if you've specified
that variant for the x11/xorg-libXt port, then it links with
the flags "-Wl,-flat_namespace" which is probably how XQuartz's
/opt/X11/lib/flat_namespace/libXt.6.dylib was built.
So, I suspect if you did a fresh build of your MacPorts ports and did
not specify the flat_namespace variant for the x11/xorg-libXt port,
it would probably fail to build the x11/openmotif port. Then if you
added the variant, it would probably succeed. But libXt would not be
built as a two-level-namespace shared library; it would be built as a
flat-namespace shared library. You can confirm this by looking for the
TWOLEVEL flag with otool:
--- 8< ---
$ otool -hv /opt/X11/lib/libXt.6.dylib
Mach header
magic cputype cpusubtype caps filetype ncmds sizeofcmds flags
MH_MAGIC_64 X86_64 ALL 0x00 DYLIB 19 2024 NOUNDEFS DYLDLINK TWOLEVEL NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
$ otool -hv /opt/X11/lib/flat_namespace/libXt.6.dylib
Mach header
MH_MAGIC_64 X86_64 ALL 0x00 DYLIB 19 2024 DYLDLINK NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
--- >8 ---
So, the flat-namespace shared library does not have the TWOLEVEL flag,
whereas the two-level-namespace shared library does. I think your
MacPorts libXt will not have the TWOLEVEL flag; this means it is a
flat-namespace shared library. And that should work, but it's similar
to my other workaround of moving the two-level-namespace libXt from
XQuartz out of the way and replacing it with XQuartz's flat-namespace
version.
Lewis
- Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
- OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes Jiro Fujita
- Re: OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes J. Lewis Muir
RE: OS X edm/medm openmotif woes Jemian, Pete R.
Re: OS X edm/medm openmotif woes Andrew Johnson
<2016>
2025
2026
<2016>
2025
2026
