Hi Giovanna,
On Fri, 2016-11-18 at 09:48 +0100, Giovanna Campogiani wrote:
> Dear colleagues,
> I am trying to make the configuration files for MCA or LabCA on a
> Scientific Linux 64bit machine and I am get the errors at the bottom
> of the email.
I see no errors, at least for the MCA build.
Is the mca.mexglx generated file found in the current folder (or
subfolders)? You just need to tell Matlab where this file and
mca/matlab subfolder are at..
Couple of weeks ago I tried MCA 4-4 with 64-bit Linux Mint Matlab
2016a. Worked nicely, no issues.
Hinko
> While searching for an answer I learnt probably the problem is within
> the fact that both MCA and LabCA are for a 32 bit pc. How to make MCA
> and LabCA compatible for a 64 bit version of MATLAB?
> Is this the real issue or am I missing something else?
> Many thanks for your support,
> best regards,
> Giovanna
> Errors reports
> when trying to make MCA
> /local/MATLAB/R2016b/bin/mex" -v -I/opt/codac-4.1/epics/base/include
> -I/opt/codac-4.1/epics/base/include/os/Linux -DEPICS_DLL_NO
> -L/opt/codac-4.1/epics/base/lib/linux-x86_64 -ldbStaticHost -lCom
> -lca mca.cpp MCAError.cpp Channel.cpp -O O.linux-x86_64/mca.mexglx
> Verbose mode is on.
> when trying to make LabCA
> make -C ./configure install
> make[1]: Entering directory `/home/codac-
> dev/MATLAB/labca_3_5_0/configure'
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64
> install
> make[2]: Entering directory `/home/codac-
> dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> perl /opt/codac-4.1/epics/base/bin/linux-x86_64/convertRelease.pl
> checkRelease
> make[2]: Leaving directory `/home/codac-
> make[1]: Leaving directory `/home/codac-
> make -C ./ezca install
> make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> install
> dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE
> -Dlinux -D_REENTRANT -O3 -g -Wall -g -m64 -fPIC -MMD
> -I. -I../O.Common -I. -I.. -I../../include/os/Linux
> -I../../include ../ezca.c
> make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> Giovanna Campogiani
> Accelerator Physics PhD Student
> Electronics Engineer
> Sapienza University of Rome
> INFN - National Institute of Nuclear Physics
> e-mail: [email protected]
- MCA or LabCA on Linux-64bit Giovanna Campogiani
Re: MCA or LabCA on Linux-64bit Ebner Simon Gregor (PSI)
<2016>
2025
2026
<2016>
2025
2026
