Hi Giovanna
This is not directly related to your question, however it might solve your base issue to have Channel Access in Matlab.
At PSI we use and (only) support this Channel Access package for Matlab: https://github.com/channelaccess/ca_matlab
No compilation no installation … you only need a recent Matlab.
Best
Simon
> On 18 Nov 2016, at 09:48, Giovanna Campogiani <[email protected]> wrote:
> Dear colleagues,
> I am trying to make the configuration files for MCA or LabCA on a Scientific Linux 64bit machine and I am get the errors at the bottom of the email.
> While searching for an answer I learnt probably the problem is within the fact that both MCA and LabCA are for a 32 bit pc. How to make MCA and LabCA compatible for a 64 bit version of MATLAB?
> Is this the real issue or am I missing something else?
> Many thanks for your support,
> best regards,
> Giovanna
> Errors reports
> when trying to make MCA
> /local/MATLAB/R2016b/bin/mex" -v -I/opt/codac-4.1/epics/base/include -I/opt/codac-4.1/epics/base/include/os/Linux -DEPICS_DLL_NO -L/opt/codac-4.1/epics/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -O O.linux-x86_64/mca.mexglx
> Verbose mode is on.
> when trying to make LabCA
> make -C ./configure install
> make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
> make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> perl /opt/codac-4.1/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
> make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
> make -C ./ezca install
> make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -g -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../include/os/Linux -I../../include ../ezca.c
> make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> Giovanna Campogiani
> Accelerator Physics PhD Student
> Electronics Engineer
> Sapienza University of Rome
> INFN - National Institute of Nuclear Physics
> e-mail: [email protected]
- Re: MCA or LabCA on Linux-64bit Giovanna Campogiani
- MCA or LabCA on Linux-64bit Giovanna Campogiani
Re: MCA or LabCA on Linux-64bit Hinxx
<2016>
2025
2026
<2016>
2025
2026
