1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linking a HIGH and LOW field to a PV
To: Bo Jakobsen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 Nov 2016 14:24:37 +0000
It is possible to define HIGH and LOW fields as CA links if you create your own custom record. The records in EPICS base ... as defined ... are not CA links.
  Ned
From: [email protected] [[email protected]] on behalf of Bo Jakobsen [[email protected]]
Sent: Tuesday, November 22, 2016 02:24 AM
To: [email protected]
Subject: Re: Linking a HIGH and LOW field to a PV
Thanks for the input
I will try this,
It is still unclear to me if the problem is to get the ao record to process the value or if it is simply not possible to define the HIGH and LOW fields as CA links.
Best
    Bo
On 2016-11-21 15:12, Steiner, Mathias wrote:
The brute force approach would be to use a calcout...
record(calcout, "$(P):SUBCRYO_SET_LOW") {
  field(INPA, "$(P):SUBCRYO_SETP_MIN.VAL CP")
  field(CALC, “A”)
  field(OUT , "$(P):SUBCRYO_SETP_S.LOW PP")
..and similar for .HIGH.
It’s the opposite of elegant but it’ll work.
cheers -mathias
From: [email protected] [mailto:[email protected]] On Behalf Of Bo Jakobsen
Sent: Monday, November 21, 2016 09:01
Subject: Linking a HIGH and LOW field to a PV
Hi
I am trying to get "limits" to work on a "Soft Channel" record.
The challenge is that I have the limit values in another record, and want to make a link between the two records.
I would therefore like to something like this:
record(ao, "$(P):SUBCRYO_SETP_S") {
  field(DESC, "Huginn Sub-cryostat system setpoint")
  field(DTYP, "Soft Channel")
  field(VAL, "300")
  field(PREC, "3")
  field(EGU, "K")
  field(PINI, "YES")
  field(HSV, "MINOR")
  field(LSV, "MINOR")
  field(LOW, "$(P):SUBCRYO_SETP_MIN.VAL CP")
  field(HIGH, "$(P):SUBCRYO_SETP_MAX CP")
which, however, does not work.
It this possible, and in that case how.
Thanks in advance.
    Bo
EPICS Base Release-Candidate Double Feature! Andrew Johnson
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
RE: Linking a HIGH and LOW field to a PV Steiner, Mathias
Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
Prev: RE: Control system remote access Mark Rivers
Next: Re: Control system remote access Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
Next: Re: Linking a HIGH and LOW field to a PV Andrew Johnson
ANJ, 22 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
