Subject: |
Re: EPICS Archiver appliance, only the first container is launched correctly |
Jeong Han Lee <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 24 Nov 2016 12:52:32 +0100 |
In addition, please use 17668 also in the date_retrieval_url
in the form that http://localhost:17668/retrieval
Han
On 11/24/2016 12:50 PM, Jeong Han Lee wrote:
I looked at my appliances.xml, and found the difference
between <cluster_inetport>localhost:17670</cluster_inetport>
and <cluster_inetport>localhost:16670</cluster_inetport>.
You might try to change the cluster_inetport.
Han
On 11/24/2016 08:06 AM, Max Power wrote:
Dear guys, installing and checking the EPICS archiver appliance I have
the following problem.
The mgmt container (the first that I launch) is launched correctly, and
it permits me to add PVs and are registered correctly both in the
webbrowser as in the mySQL data base, but the following containers does
not execute because all of them report in the log file the same error:
Caused by: com.hazelcast.core.HazelcastException: Port [17670] is
already in use and auto-increment is disabled. Hazelcast cannot start
I understand waht it means, but I follow the configuration explained in
the https://slacmshankar.github.io/epicsarchiver_docs/installguide.html
my appliance configuration is:
<appliances>
<appliance>
<identity>appliance0</identity>
<mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
<engine_url>http://localhost:17666/engine/bpl</engine_url>
<etl_url>http://localhost:17667/etl/bpl</etl_url>
<retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
<data_retrieval_url>http://localhost/retrieval</data_retrieval_url>
</appliance>
</appliances>
the way in which I launch the cluster is:
function startTomcatAtLocation() {
if [ -z "$1" ]; then echo "startTomcatAtLocation called without any
arguments"; exit 1; fi
export CATALINA_HOME=$TOMCAT_HOME
export CATALINA_BASE=$1
echo "Starting tomcat at location ${CATALINA_BASE}"
ARCH=`uname -m`
if [[ $ARCH == 'x86_64' || $ARCH == 'amd64' ]]
then
echo "Using 64 bit versions of libraries"
### export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:${LD_LIBRARY_PATH}
export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/max/EPICS/base/lib/linux-x86_64:${LD_LIBRARY_PATH}
else
echo "Using 32 bit versions of libraries"
export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86:${LD_LIBRARY_PATH}
fi
pushd ${CATALINA_BASE}/logs
${CATALINA_HOME}/bin/jsvc \
-server \
-cp
${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-juli.jar:/home/max/scratch/mgmt/webapps/WEB-INF/lib/log4j-1.2.17.jar
${JAVA_OPTS} \
-Dcatalina.base=${CATALINA_BASE} \
-Dcatalina.home=${CATALINA_HOME} \
-cwd ${CATALINA_BASE}/logs \
-outfile ${CATALINA_BASE}/logs/catalina.out \
-errfile ${CATALINA_BASE}/logs/catalina.err \
-pidfile ${CATALINA_BASE}/pid \
org.apache.catalina.startup.Bootstrap run
popd
function start() {
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/engine
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/etl
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/retrieval
any idea?
Thank you in advance
- EPICS Archiver appliance, only the first container is launched correctly Max Power
- Re: EPICS Archiver appliance, only the first container is launched correctly Jeong Han Lee
Re: EPICS Archiver appliance, only the first container is launched correctly Shankar, Murali
<2016>
2025
2026
EPICS on RTEMS: nfsmount problem "भावना नितिन मेढ़"
<2016>
2025
2026
ANJ, 24 Nov 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
