but the following containers does
not execute because all of them report in the log file the same error:
I created a sample install based on the portions of the script you enclosed and I could start up the server correctly. I assume that you are setting up the appliance identity and the xml file somewhere else in the script. Something that looks like so.
export ARCHAPPL_MYIDENTITY=appliance0
export ARCHAPPL_APPLIANCES=/scratch/Work/temp/aadeploytest/appliances.xml
export ARCHAPPL_DEPLOY_DIR=/scratch/LargeDisk/tomcats
Can you send me (perhaps offline) all your logs for all your components? I will respond to this thread...
Murali
