1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Archiver appliance, only the first container is launched correctly
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Nov 2016 17:34:11 +0000
I am reasonably sure that you have some exception in the log that aborted the startup process.
Could you please check for exceptions in all your log files? I typically use something like so...
find /arch/tomcats -wholename '*/logs/*' -exec grep -l xception {} \;
find /arch/tomcats -wholename '*/logs/*' -exec grep -l FATAL {} \;
Murali
Sent: Thursday, November 24, 2016 7:50 AM
To: [email protected]; [email protected]
but the following containers does
not execute because all of them report in the log file the same error:
I created a sample install based on the portions of the script you enclosed and I could start up the server correctly. ​ I assume that you are setting up the appliance identity and the xml file somewhere else in the script. Something that looks like so.
export ARCHAPPL_MYIDENTITY=appliance0
export ARCHAPPL_APPLIANCES=/scratch/Work/temp/aadeploytest/appliances.xml
export ARCHAPPL_DEPLOY_DIR=/scratch/LargeDisk/tomcats
Can you send me (perhaps offline) all your logs for all your components? I will respond to this thread...
Murali
Re: EPICS Archiver appliance, only the first container is launched correctly Max Power
Re: EPICS Archiver appliance, only the first container is launched correctly Shankar, Murali
Prev: Re: EPICS Archiver appliance, only the first container is launched correctly Shankar, Murali
Next: Re: EPICS Archiver appliance, only the first container is launched correctly Max Power
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
