Hi Murali, I am going to check the logs, but by the moment I pass you the entire script that I use, that is based in one I took from EPICS archiver appliance website:Take note that some environment variables that ar note defined in this script, are in the .bash_profile Thanks a lot for your answers #!/bin/bash # Sample startup script for the archiver appliance # Please change the various environment variables to suit your environment. # We assume that we inherit the EPICS environment variables from something that calls this script # However, if this is a init.d startup script, this is not going to be the case and we'll need to add them here. # This includes setting up the LD_LIBRARY_PATH to include the JCA .so file. #D COMMENTED ###source /opt/local/setEPICSEnv.sh export EPICS_CA_AUTO_ADDR_LIST=yes export EPICS_CA_ADDR_LIST=127.0.0.1 export JAVA_HOME=/usr/java/jdk1.8.0_73 export PATH=${JAVA_HOME}/bin:${PATH} # We use a lot of memory; so be generous with the heap. ###export JAVA_OPTS="-XX:MaxPermSize=128M -XX:+UseG1GC -Xmx2G -Xms1G -ea" export JAVA_OPTS="-Xmx756M -Xms512M -ea" # Set up Tomcat home export TOMCAT_HOME=/home/max/Downloads/apache-tomcat-7.0.72 # Set up the root folder of the individual Tomcat instances. export ARCHAPPL_DEPLOY_DIR=/home/max/scratch # Set appliance.xml and the identity of this appliance export ARCHAPPL_APPLIANCES=/home/max/Downloads/archappl_v0.0.1_SNAPSHOT_20-September-2016T13-50-17/arch_appliances_folder/production_appliances.xml export ARCHAPPL_MYIDENTITY="appliance0" # If you have your own policies file, please change this line. # export ARCHAPPL_POLICIES=/nfs/epics/archiver/production_policies.py # Set the location of short term and long term stores; this is necessary only if your policy demands it export ARCHAPPL_SHORT_TERM_FOLDER=/home/max/Downloads/archappl_v0.0.1_SNAPSHOT_20-September-2016T13-50-17/arch/sts/ArchiverStore export ARCHAPPL_MEDIUM_TERM_FOLDER=/home/max/Downloads/archappl_v0.0.1_SNAPSHOT_20-September-2016T13-50-17/arch/mts/ArchiverStore export ARCHAPPL_LONG_TERM_FOLDER=/home/max/Downloads/archappl_v0.0.1_SNAPSHOT_20-September-2016T13-50-17/arch/lts/ArchiverStore if [[ ! -d ${TOMCAT_HOME} ]] then echo "Unable to determine the source of the tomcat distribution" exit 1 fi if [[ ! -f ${ARCHAPPL_APPLIANCES} ]] then echo "Unable to find appliances.xml at ${ARCHAPPL_APPLIANCES}" exit 1 fi # Enable core dumps in case the JVM fails ulimit -c unlimited function startTomcatAtLocation() { if [ -z "$1" ]; then echo "startTomcatAtLocation called without any arguments"; exit 1; fi export CATALINA_HOME=$TOMCAT_HOME export CATALINA_BASE=$1 echo "Starting tomcat at location ${CATALINA_BASE}" ARCH=`uname -m` if [[ $ARCH == 'x86_64' || $ARCH == 'amd64' ]] then echo "Using 64 bit versions of libraries" ### export LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:${LD_LIBRARY_PATH} export LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/max/EPICS/base/lib/linux-x86_64:${LD_LIBRARY_PATH} else echo "Using 32 bit versions of libraries" export LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86:${LD_LIBRARY_PATH} fi pushd ${CATALINA_BASE}/logs ${CATALINA_HOME}/bin/jsvc \ -server \ -cp ${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-juli.jar:/home/max/scratch/mgmt/webapps/WEB-INF/lib/log4j-1.2.17.jar \ ${JAVA_OPTS} \ -Dcatalina.base=${CATALINA_BASE} \ -Dcatalina.home=${CATALINA_HOME} \ -cwd ${CATALINA_BASE}/logs \ -outfile ${CATALINA_BASE}/logs/catalina.out \ -errfile ${CATALINA_BASE}/logs/catalina.err \ -pidfile ${CATALINA_BASE}/pid \ org.apache.catalina.startup.Bootstrap run popd } function stopTomcatAtLocation() { if [ -z "$1" ]; then echo "stopTomcatAtLocation called without any arguments"; exit 1; fi export CATALINA_HOME=$TOMCAT_HOME export CATALINA_BASE=$1 echo "Stopping tomcat at location ${CATALINA_BASE}" pushd ${CATALINA_BASE}/logs ${CATALINA_HOME}/bin/jsvc \ -server \ -cp ${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-juli.jar \ ${JAVA_OPTS} \ -Dcatalina.base=${CATALINA_BASE} \ -Dcatalina.home=${CATALINA_HOME} \ -cwd ${CATALINA_BASE}/logs \ -outfile ${CATALINA_BASE}/logs/catalina.out \ -errfile ${CATALINA_BASE}/logs/catalina.err \ -pidfile ${CATALINA_BASE}/pid \ -stop \ org.apache.catalina.startup.Bootstrap popd } function stop() { stopTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/engine stopTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/retrieval stopTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/etl stopTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt } function start() { startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt sleep 20s startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/engine sleep 20s startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/etl sleep 20s startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/retrieval } # See how we were called. case "$1" in start) start ;; stop) stop ;; restart) stop start ;; *) echo $"Usage: $0 {start|stop|restart}" exit 2 esac 2016-11-24 18:34 GMT+01:00 Shankar, Murali <[email protected]>:
| ANJ, 25 Nov 2016 |
Home
News
About
Talk
Base
Modules
Extensions
