1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base Release-Candidate Double Feature!
To: Andrew Johnson <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 30 Nov 2016 16:48:29 +0100
Hi Andrew,
This change indeed looks good and appropriate.
Please commit and merge up.
Thanks a lot - to you and Xiaoquiang,
~Ralph
On Fri, Nov 11, 2016 at 10:47 PM, Andrew Johnson <[email protected]> wrote:
Hi Xiaoqiang,
On 11/11/2016 07:54 AM, Wang Xiaoqiang wrote:
> In the dynamic array support of PCAS, it does not handle gdd of
> container type. Here I put up a fix,
> https://github.com/xiaoqiangwang/epics-base/commit/c76a2399ccf5bfb5f76a45ea56df360236d889aa
Thanks for your report and the fix. I assume the deadlock issue that you
reported yesterday is a separate problem.
If either Ralph Lange or Bruce Hill can confirm that the above fix looks
good to them I will commit it to the 3.14 branch and merge up to 3.15.
- Andrew
EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Wang Xiaoqiang
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Prev: RE: RTEMS Support in IPAC 2.14 for Acromag IP520? Williams Jr., Ernest L.
Next: Re: RTEMS Support in IPAC 2.14 for Acromag IP520? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Next: Re: EPICS Base Release-Candidate Double Feature! Shankar, Murali
ANJ, 30 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
