1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL sequencer apparently losing connection to underlying network
To: Kevin Meyer <[email protected]>, Tech-talk <[email protected]>
Date: Wed, 30 Nov 2016 19:40:53 +0100
Hi Kevin
On 29.11.2016 10:31, Kevin Meyer wrote:
> Responses inline, below, but basically: the SNL thread is still running:
> ----- On 28 Nov, 2016, at 17:31, Kasemir, Kay [email protected] wrote:
>>> In one of the sequencers, I have a call out to to a Python script that calls a
>>> web service (to Olog, to create an electronic lab-book entry).
>> Is that the one that's occasionally hanging up?
>> Are you calling out to python from somewhere within the SNL code, like
>> when (..)
>>    .. call out to python
>> I assume that all the SNL code is executed within some 'main' thread of the
>> sequencer.
>> Maybe the call out to python hangs, so the core SNL thread is stuck and no
>> longer updating anything.
No this is not the case as you found out. A separate thread is spawned
for each state set.
Does you Python program use CA? If yes, then I have a theory: the
problem comes from the Python program trying to create a CA client
context, but ending up re-using the one from the state thread. And when
the Python ends, the context is destroyed, effectively disabling the
state thread's CA capability.
To test this, replace the Python program with a very simple program that
does not import any CA stuff. If the problem persists this means my
guess was wrong.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
Prev: Re: RTEMS Support in IPAC 2.14 for Acromag IP520? Andrew Johnson
Next: sscan module difficulties with EPICS 3.15 base Carl Willis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
Next: Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
ANJ, 01 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
