1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL sequencer apparently losing connection to underlying network
To: Benjamin Franksen <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 1 Dec 2016 10:15:58 +0100 (CET)
Hi Ben,
> ----- On 30 Nov, 2016, at 19:40, Benjamin Franksen [email protected] wrote:
> Hi Kevin
>>> I assume that all the SNL code is executed within some 'main' thread of the
>>> sequencer.
>>> Maybe the call out to python hangs, so the core SNL thread is stuck and no
>>> longer updating anything.
> No this is not the case as you found out. A separate thread is spawned
> for each state set.
> Does you Python program use CA? If yes, then I have a theory: the
> problem comes from the Python program trying to create a CA client
> context, but ending up re-using the one from the state thread. And when
> the Python ends, the context is destroyed, effectively disabling the
> state thread's CA capability.
Yes, the Python program uses pyEpics's epics.caget, but there are some complications here:
1. The Python context is created in the sequencer's global entry block and shut down in the global exit block (the PyObject's are initialised there and re-used in subsequent State entry calls).
2. How would the Python process EPICS get ahold of the calling-sequencer's C EPICS context?
3. The susceptible sequencer still works fine if I stop one of the *other* sequencers (that updates two of the PVs) used, above.
> To test this, replace the Python program with a very simple program that
> does not import any CA stuff. If the problem persists this means my
> guess was wrong.
When testing I could get the sequencer to work by commenting out only *some* (and leaving in others) of the epics.caget(xxx) calls.
Kevin
Kevin Meyer
Cosylab, Ljubljana, Slovenia
Telephone: +386-(0)1-320-47-82   Mobile: +386-(0)70-260-321
Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
Prev: RE: sscan module difficulties with EPICS 3.15 base Mark Rivers
Next: Automatic flat db generation Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
Next: Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
ANJ, 01 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
