Those look like they might be RFC 2217 remote serial port configuration. Try specifying the COM option to the IP address argument to the ASYN port configuration command.
I have read the manual for the MPC that you sent. Indeed it should never sent the unprintable characters like \377\372. I see that you are using a TCP connection to the MPC, which means you are using its internal Lantronix terminal server. I think you may have some setting on the Lantronix wrong, for example the start bits, stop bits, or parity. Can you open a Web page to the Lantronix and see what settings you are using?
- RE: Capturing data from string which is sent by device Mark Rivers
IOC segfaults with epicsMutexLock (pmutexNode=0x0) Blaz Kranjc
<2016>
2025
2026
Operational experience for Keithley 6485/6487 Sapozhnikov, Leonid
<2016>
2025
2026
ANJ, 05 Dec 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
