1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: deadlock in pcas 3.14.12.6-rc1
To: Bruce Hill <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 7 Dec 2016 12:08:21 +0100
Hi Bruce,
Thanks. The crash cannot be reproduced with this fix.
Since the casPVI lock is now acquire during channel creation,
just a purely theoretical thinking, is there a chance that the deadlock would happen if a new CA client wants to connect while PCAS application is calling postEvent?
I am running the same test again, and in addition four loops to make continuous caget requests.
$ while [ 1 ]; do caget MTEST:MinValue; done;
Best
Xiaoqiang
On 12/07/2016 10:45 AM, Bruce Hill wrote:
Hi Xiaoqiang,
Thanks, I was able to reproduce the bug using your suggestions.
I've submitted a proposed fix on launchpad.   Please let me know if you
have a chance to try it.    My version ran all day today w/o crashing.
https://code.launchpad.net/~bhill/epics-base/pcas-deadlock-fix-3.14/+merge/312638
<https://code.launchpad.net/%7Ebhill/epics-base/pcas-deadlock-fix-3.14/+merge/312638>
Cheers,
- Bruce
On 12/6/2016 1:38 AM, Wang Xiaoqiang (PSI) wrote:
Hi Bruce,
I replied you here
https://github.com/paulscherrerinstitute/pcaspy/issues/29#issuecomment-265103000
I carried out the described test procedure on a SL6 64bit Linux PC.
The problem appears definitely in a few seconds.
Best
Xiaoqiang
-----Original Message-----
[mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Dienstag, 6. Dezember 2016 04:15
To: [email protected]
Hi Xiaoqiang,
Do you have a pcaspy example that I can run to reproduce this?
I'm running pcaspy 0.6.2 currently, but could also build from a github
branch if available.
- Bruce
On 11/10/2016 08:59 AM, Wang Xiaoqiang (PSI) wrote:
I am testing the support of dynamic array in the recent base
3.14.12.6-rc1.
Using a normal pcaspy application, which updates ~15 Hz. It
repeatedly gets into a deadlock state.
The analysis has been put up here
The solution could be reversing the lock order during
casEventSys::process. But it does not seem to be easy, because the
chain of calls involved.
Best
Xiaoqiang
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
deadlock in pcas 3.14.12.6-rc1 Wang Xiaoqiang (PSI)
RE: deadlock in pcas 3.14.12.6-rc1 Wang Xiaoqiang (PSI)
Prev: Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
Next: SureStep microstepping drive Omitto, Diego
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
ANJ, 07 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
