1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gcc under NixOS
To: [email protected]
Date: Thu, 8 Dec 2016 11:04:48 -0500
On 12/08/2016 06:52 AM, Hinko Kocevar wrote:
> Hi,
> Since NixOS is not using /usr/bin/gcc how would one setup the EPICS base
> configuration files to find gcc?
Assuming nixos follows the usual gcc conventions, and assuming you are
building on a nixos host, set GNU_TARGET and perhaps GNU_DIR in (I
think) "configure/os/CONFIG_SITE.Common.$(EPICS_HOST_ARCH)".  The
cross-compile targets provide examples of what this looks like.
https://github.com/epics-base/epics-base/blob/3.16/configure/os/CONFIG_SITE.linux-x86.linux-arm
Gcc under NixOS Hinko Kocevar
Prev: Re: TPG-256 driver Heinz Junkes
Next: Re: base-3.14.12.5 CONFIG_SITE.linux-x86_64.UnixCommon Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Gcc under NixOS Hinko Kocevar
Next: Base 3.14.12.6 Andrew Johnson
ANJ, 09 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
