1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: multiple include not supprted with EPICS 3.15.2
To: <[email protected]>
Date: Fri, 6 Jan 2017 10:30:07 +0100
Yes that's what I did,
I just wanted to be sure that this is the expected behavior
Le 05/01/2017 à 17:56, Andrew Johnson a écrit :
Hi Christophe,
On 01/05/2017 09:57 AM, haquin wrote:
years ago I created a record drived from genSub, in the 'src' directory
there are several ".dbd" files which may include
"menuFType.dbd" and "menuAlarmSevr.dbd".
It worked well with EPICS 3.14, but with EPICS 3.15.2 at compilation I
have errors because of multiple include of those
files.
enum defined in "menuFType.dbd" and "menuAlarmSevr.dbd" are considered
to be redeclared.
Try removing the include lines from your Record.dbd file that pull in
those particular menu*.dbd files. The menu definitions are not actually
needed when the Record.dbd file is converted in to a Record.h file, and
they do get included in the base.dbd file so they will already be
defined when the IOC's top-level DBD file is created.
I think this will solve your issue (take a look at the aSubRecord in
Base for another record that was derived from the genSub, which might
answer some other questions that arise).
- Andrew
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
multiple include not supprted with EPICS 3.15.2 haquin
Re: multiple include not supprted with EPICS 3.15.2 Andrew Johnson
Prev: RE: ca_search() and "preemptive callback" Mooney, Tim M.
Next: vxWorks 6.9 compiler problem on large file systems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: multiple include not supprted with EPICS 3.15.2 Andrew Johnson
Next: ca_search() and "preemptive callback" Michael Westfall
