Folks,
We are trying to use VxWorks6.9.4 on a Linux system with a 5.4TB file system. We get the following error when building an IOC application on this file system:
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I.. -I../../include/os/vxWorks -I../../include -I/corvette/usr/local/epics/base/include/os/vxWorks -I/corvette/usr/local/epics/base/include -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip ../drvIpac.c
cc1: error: .: Value too large for defined data type
cc1: error: ..: Value too large for defined data type
cc1: error: ../../include: Value too large for defined data type
cc1: error: ../drvIpac.c: Value too large for defined data type
make[2]: *** [drvIpac.o] Error 1
make[2]: Leaving directory `/home/epics/support/ipac-2-13/drvIpac/O.vxWorks-ppc32'
make[1]: *** [install.vxWorks-ppc32] Error 2
make[1]: Leaving directory `/home/epics/support/ipac-2-13/drvIpac'
make: *** [drvIpac.install] Error 2
We suspect this is because the VxWorks compiler is a 32-bit application that was built without the -D_FILE_OFFSET_BITS=64 flag?
EPICS base built fine on this machine when it was located on a 50GB file system. When we moved it to the 5.4TB file system it also failed to build with the same error.
Has anyone else seen this problem, and if so is there a solution other than not compiling with vxWorks on such a large file system?
If we need to repartition this drive we need to know how big we can safely make it. Since the Linux blocks are 1 kB, is the limit 2 TB (2^31 blocks) or 4 TB (2^32 blocks)?
- RE: vxWorks 6.9 compiler problem on large file systems Mark Rivers
Re: multiple include not supprted with EPICS 3.15.2 haquin
<2017>
2025
softGlueZynq R1-0 release Mooney, Tim M.
<2017>
2025
