> The weird thing that it happens only with this module.
Which module is it happening with? The error messages in your original message are not complete, so they don't show which module was being built when you got those errors.
Sent: Monday, January 09, 2017 1:12 AM
To: Mark Rivers; [email protected]
Subject: RE: synApps_5_8 build error
Hello Mark
Yes it fixes the problem by hard coding the paths not using env. The weird thing that it happens only with this module.
Abdalla.
-----Original Message-----
Sent: Sunday, January 08, 2017 3:50 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
If you change /home/control/epics/support/synApps_5_8/support/configure/RELEASE to define
SUPPORT=/home/control/epics/support/synApps_5_8/support/
EPICS_BASE=/home/control/epics/base-3.14.12.3
does that fix the problem? Maybe it is not picking up the environment variables correctly.
From: [email protected] [[email protected]] on behalf of Abdalla Ahmad [[email protected]]
Sent: Sunday, January 08, 2017 12:26 AM
To: [email protected]
Subject: synApps_5_8 build error
Hi
I downloaded the mentioned version of synApps and I modified SUPPORT and EPICS_BASE in configure/RELEASE file as:
SUPPORT=$(SYNAPPS_SUPPORT)
EPICS_BASE=$(ENV_EPICS_BASE)
These variables are already defined in .bashrc and exported. The list of modules for our site is
Asyn
Allen_Bradlley
Autosave
Busy (Added to resolve a similar error at compiling asyn ) Calc IP IPAC Motor SNCSEQ SSCAN STREAM
Executing 'make release' then make gives the following:
Definition of SNCSEQ conflicts with SUPPORT support.
In this application a RELEASE file defines
SNCSEQ = /home/control/epics/support/synApps_5_8/support/seq-2-2-1
but SUPPORT at /home/control/epics/support/synApps_5_8/support defines
SNCSEQ = /seq-2-2-1
Definition of EPICS_BASE conflicts with SUPPORT support.
EPICS_BASE = /home/control/epics/base-3.14.12.3
EPICS_BASE =
Definition of SUPPORT conflicts with SUPPORT support.
SUPPORT = /home/control/epics/support/synApps_5_8/support
SUPPORT =
I have no clue of where these wrong definitions are. I thought of giving hard coded paths for the aforementioned variables instead of env ones and the build works fine. I believe on synApps 5.6 we did not face that error.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
- synApps_5_8 build error Abdalla Ahmad
- RE: synApps_5_8 build error Mark Rivers
- RE: synApps_5_8 build error Abdalla Ahmad
RE: Asyn and devices with changing register map tom.cobb
Multiple OS Build Hugo Slepicka
<2017>
2025
2026
<2017>
2025
2026
