1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with seq 2.2.4 on Windows
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Fri, 13 Jan 2017 11:02:49 +0000
Hi Mark,
snl.c is autogenerated using the lemon parser and lemon was updated between 2.2.3 and 2.2.4
Looking at the code failing it is:
    }else{
      assert( yyact == YY_ERROR_ACTION );
      yyminorunion.yy0 = yyminor;
#ifdef YYERRORSYMBOL
      int yymx;
#endif
I think Visual Studio 2010 doesn’t like the declaration of  yymx  occurring after an assignment, this wasn’t allowed prior to the C99 standard I believe. If you edit the corresponding place in snl.lt and move the yymx declaration to before the assert does it them generate an snl.c that compiles OK?
Freddie
Sent: 13 January 2017 00:30
To: Mark Rivers; 'Benjamin Franksen'; Akeroyd, Freddie (STFC,RAL,ISIS)
I should add that seq 2.2.3 builds OK with the same setup, so I have reverted to that for now.
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, January 12, 2017 6:06 PM
To: 'Benjamin Franksen'; [email protected]
Subject: Problems with seq 2.2.4 on Windows
Hi Ben and Freddie,
I am having problems building seq 2.2.4 on Windows:
-          Visual Studio 2010
-          EPICS 3.15.5
-          windows-x64 and windows-x64-static architectures
This is the complete output when building.
make -C J:/epics/support/seq-2-2-4 install
make[1]: Entering directory 'J:/epics/support/seq-2-2-4'
make -C ./configure install
make[2]: Entering directory 'J:/epics/support/seq-2-2-4/configure'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../..
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/configure/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/convertRelease.pl checkRelease
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/configure/O.windows-x64-static'
make[2]: Leaving directory 'J:/epics/support/seq-2-2-4/configure'
make -C ./src install
make[2]: Entering directory 'J:/epics/support/seq-2-2-4/src'
make -C ./pv install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/pv'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../../..
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/pv/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m pv.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        pv.obj ../pv.c
cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3        -MT    -I. -I../O.Common -I. -I. -I.. -I../../../include/compi
ler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -
c ../pv.c
pv.c
lib -nologo -verbose -out:pv.lib        pv.obj
Appending pv.obj
"Installing library ../../../lib/windows-x64-static/pv.lib"
mkdir ../../../lib/windows-x64-static
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/pv/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/pv'
make -C ./common install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/common'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/common/O.windows-x64-static'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/common/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/common'
make -C ./seq install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/seq'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/seq/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_queue.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_queue.obj ../seq_queue.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_cmd.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_cmd.obj ../seq_cmd.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_qry.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_qry.obj ../seq_qry.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_prog.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_prog.obj ../seq_prog.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_mac.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_mac.obj ../seq_mac.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_if.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../in
clude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_if.obj ../seq_if.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_ca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../in
clude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_ca.obj ../seq_ca.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_task.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_task.obj ../seq_task.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_main.obj ../seq_main.c
c ../seq_main.c
seq_main.c
c ../seq_task.c
seq_task.c
c ../seq_ca.c
seq_ca.c
c ../seq_if.c
seq_if.c
c ../seq_mac.c
seq_mac.c
c ../seq_prog.c
seq_prog.c
c ../seq_qry.c
seq_qry.c
c ../seq_cmd.c
seq_cmd.c
c ../seq_queue.c
seq_queue.c
lib -nologo -verbose -out:seq.lib        seq_main.obj seq_task.obj seq_ca.obj seq_if.obj seq_mac.obj seq_prog.obj seq_qry.obj seq_cmd.obj seq_queue.obj
Appending seq_queue.obj
Appending seq_cmd.obj
Appending seq_qry.obj
Appending seq_prog.obj
Appending seq_mac.obj
Appending seq_if.obj
Appending seq_ca.obj
Appending seq_task.obj
Appending seq_main.obj
"Installing library ../../../lib/windows-x64-static/seq.lib"
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/seq/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/seq'
make -C ./lemon install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/lemon'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/lemon/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m lemon.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        lemon.obj ../lemon.c
c ../lemon.c
lemon.c
link -nologo   -incremental:no -opt:ref -release  /MACHINE:X64              -out:lemon.exe       lemon.obj       ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
"Installing created executable ../../../bin/windows-x64-static/lemon.exe"
mkdir ../../../bin/windows-x64-static
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/lemon/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/lemon'
make -C ./snc install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/snc'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/snc/O.windows-x64-static'
J:/epics/support/seq-2-2-4/bin/windows-x64-static/lemon.exe o=. ../snl.lem
2 parsing conflicts.
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m snl.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inclu
de -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        snl.obj snl.c
re2c.exe -s -b -o lexer.c ../snl.re
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        lexer.obj lexer.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        builtin.obj ../builtin.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        sym_table.obj ../sym_table.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../.
./include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_tables.obj ../gen_tables.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../
../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_ss_code.obj ../gen_ss_code.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_code.obj ../gen_code.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        analysis.obj ../analysis.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        var_types.obj ../var_types.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../incl
ude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        node.obj ../node.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../incl
ude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        main.obj ../main.c
c lexer.c
lexer.c
../snl.re(90) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(91) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(93) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(138) : warning C4267: '=' : conversion from 'size_t' to 'uint', possible loss of data
../snl.re(213) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../snl.re(364) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(380) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../snl.re(431) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
c snl.c
snl.c
./snl.c(2410) : error C2143: syntax error : missing ';' before 'type'
./snl.c(2440) : error C2065: 'yymx' : undeclared identifier
./snl.c(2441) : error C2065: 'yymx' : undeclared identifier
./snl.c(2452) : error C2065: 'yymx' : undeclared identifier
./snl.c(2467) : error C2065: 'yymx' : undeclared identifier
H:/epics/base-3.15.5/configure/RULES_BUILD:229: recipe for target 'snl.obj' failed
make[4]: *** [snl.obj] Error 2
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/snc/O.windows-x64-static'
H:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static' failed
make[3]: *** [install.windows-x64-static] Error 2
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/snc'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'snc.install' failed
make[2]: *** [snc.install] Error 2
make[2]: Leaving directory 'J:/epics/support/seq-2-2-4/src'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory 'J:/epics/support/seq-2-2-4'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'J:/epics/support/seq-2-2-4.install' failed
make: *** [J:/epics/support/seq-2-2-4.install] Error 2
RE: Problems with seq 2.2.4 on Windows Mark Rivers
Re: Problems with seq 2.2.4 on Windows Andrew Johnson
Prev: RE: Problems with seq 2.2.4 on Windows Mark Rivers
Next: EPICS Device Support for cRIO and FlexRIO FPGA based devices is now available Enrique Bernal
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Problems with seq 2.2.4 on Windows Mark Rivers
