Subject: Re: Problems with seq 2.2.4 on Windows
To: <[email protected]>
Date: Fri, 13 Jan 2017 11:02:56 -0600
On 01/13/2017 05:02 AM, [email protected] wrote:
> snl.c is autogenerated using the lemon parser and lemon was updated
> between 2.2.3 and 2.2.4
> Looking at the code failing it is:
>     }else{
>       assert( yyact == YY_ERROR_ACTION );
>       yyminorunion.yy0 = yyminor;
> #ifdef YYERRORSYMBOL
>       int yymx;
> #endif
> I think Visual Studio 2010 doesn’t like the declaration of  yymx
> occurring after an assignment, this wasn’t allowed prior to the C99
> standard I believe.
IIRC the vxWorks 5.5.x compiler will also object to the above source
code; K&R and ANSI C89-rules required all variable declarations to
appear before any other statement within a block, which the above code
violates when YYERRORSYMBOL is defined. GCC has allowed it for a long
time though, so some programmers might never have come across the rule.
Note that the rule applied within any {code block;}, it didn't require
all variable declarations to appear at the beginning of a subroutine
definition. A lot of older EPICS code was written that way, but I don't
know if that was due to misunderstanding the rule or just preferring
that particular coding style. I usually move variable declarations into
the inner-most scope possible when I work on such code nowadays.
- Andrew
Problems with seq 2.2.4 on Windows Mark Rivers
RE: Problems with seq 2.2.4 on Windows Mark Rivers
RE: Problems with seq 2.2.4 on Windows freddie.akeroyd
Prev: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Next: Re: Problem with parallel make with seq 2.2.4 on Linux Andrew Johnson
Prev: RE: Problems with seq 2.2.4 on Windows Mark Rivers
Next: EPICS Device Support for cRIO and FlexRIO FPGA based devices is now available Enrique Bernal
