1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN VXI-11
To: Eric Norum <[email protected]>, Mark Rivers <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Sun, 15 Jan 2017 03:17:37 +0100
Am 10.01.2017 um 18:58 schrieb Eric Norum:
> I’m attempting to communicate with a Keysight 53210A frequency
> counter using VXI-11/ASYN/StreamDevice.  I’m seeing all sorts of
> problems when the driver attempts to set up the SRQ link — to the
> point where the windows application on the frequency counter crashes
> and puts up a ‘.exe failed’ message (upside down!) on the instrument
> screen.
> I had a look at the code in drvVxi11.c and by moving the SRQ code
> inside the ‘isGpibLink’ test everything seems to work.  This change
> also gets VXI-11 communication working with some other instruments
> that also failed before.
> What are your thoughts on this change? Does anyone use SRQ with
> non-'GPIB' devices?  If so, how did you make it work?
I have not done this, personally, but I know that the SRQ "back channel"
is officially part of the VXI-11 protocol definition and that devices
/should/ implement it, or, failing that, at least catch attempts to
connect and report an "unsupported feature" error code back to the
client, rather than doing funny stuff on the instrument screen!
That they fail to do so is a bug. First and foremost, you should take
your complaint to the vendor of the instrument.
It might not be possible to convince enough vendors of buggy VXI-11
instruments to fix their firmware, and even in case they they eventually
do that this might take longer than we want to wait. So I guess the most
reasonable approach for asyn is to offer a command (i.e. startup script
callable function) to selectively disable SRQ functionality (including
the request for an SRQ channel at startup) for a given asyn link. In
this way we could keep the (documented) standard VXI-11 behaviour while
giving users a way to easily switch it off and work around these
formware bugs.
Cheers
Ben
> diff -U50 -r ../asyn4-30.orig/asyn/vxi11/drvVxi11.c
> ./asyn/vxi11/drvVxi11.c --- ../asyn4-30.orig/asyn/vxi11/drvVxi11.c
> 2016-08-23 09:23:36.000000000 -0700 +++ ./asyn/vxi11/drvVxi11.c
> 2017-01-10 09:19:06.969887000 -0800 @@ -909,102 +909,102 @@
> pvxiPort->server.lid = link; pvxiPort->server.connected = TRUE;
> pvxiPort->ctrlAddr = -1; if(pvxiPort->isGpibLink) { /* Ask the
> controller's gpib address.*/ status = vxiBusStatus(pvxiPort,
> VXI_BSTAT_BUS_ADDRESS,pvxiPort->defTimeout,&pvxiPort->ctrlAddr);
> if(status!=asynSuccess) { asynPrint(pasynUser,ASYN_TRACE_ERROR, "%s
> vxiConnectPort cannot read bus status initialization aborted\n",
> pvxiPort->portName); if (pvxiPort->server.connected)
> vxiDisconnectPort(pvxiPort); return status; } /* initialize the
> vxiPort structure with the data we have got so far */
> pvxiPort->primary[pvxiPort->ctrlAddr].primary.lid = link;
> pvxiPort->primary[pvxiPort->ctrlAddr].primary.connected = TRUE; /*
> now we can use vxiBusStatus; if we are not the controller fail */
> status = vxiBusStatus(pvxiPort, VXI_BSTAT_SYSTEM_CONTROLLER,
> pvxiPort->defTimeout,&isController); if(status!=asynSuccess) {
> asynPrint(pasynUser,ASYN_TRACE_ERROR, "%s vxiConnectPort vxiBusStatus
> error initialization aborted\n", pvxiPort->portName); if
> (pvxiPort->server.connected) vxiDisconnectPort(pvxiPort); return
> status; } if(isController == 0) { status = vxiBusStatus(pvxiPort,
> VXI_BSTAT_CONTROLLER_IN_CHARGE, pvxiPort->defTimeout,&isController);
> vxiConnectPort vxiBusStatus error initialization aborted\n",
> vxiDisconnectPort(pvxiPort); return asynError; } if(isController ==
> 0) { asynPrint(pasynUser,ASYN_TRACE_ERROR, "%s vxiConnectPort neither
> system controller nor " "controller in charge -- initialization
> aborted\n", pvxiPort->portName); if (pvxiPort->server.connected)
> vxiDisconnectPort(pvxiPort); return asynError; } } +
> vxiCreateIrqChannel(pvxiPort,pasynUser); } -
> pasynManager->exceptionConnect(pvxiPort->pasynUser); return
> asynSuccess; }
> static asynStatus vxiDisconnectPort(vxiPort *pvxiPort) { int
> addr,secondary; asynUser     *pasynUser = pvxiPort->pasynUser;
> if(!pvxiPort->server.connected) {
> asynPrint(pasynUser,ASYN_TRACE_ERROR, "%s vxiDisconnectPort but not
> connected\n",pvxiPort->portName); return asynError; } if(pasynUser)
> asynPrint(pasynUser,ASYN_TRACE_FLOW, "%s
> vxiDisconnectPort\n",pvxiPort->portName);
> if(!pvxiPort->isSingleLink) for(addr = 0; addr < NUM_GPIB_ADDRESSES;
> addr++) { devLink *pdevLink;
> pdevLink = &pvxiPort->primary[addr].primary; if(pdevLink->connected)
> { if(addr!=pvxiPort->ctrlAddr) { vxiDestroyDevLink(pvxiPort,
> pdevLink->lid); vxiDisconnectException(pvxiPort,addr); }
> pdevLink->lid = 0; pdevLink->connected = FALSE; } for(secondary = 0;
> secondary < NUM_GPIB_ADDRESSES; secondary++) { pdevLink =
> &pvxiPort->primary[addr].secondary[secondary];
> if(pdevLink->connected) { vxiDestroyDevLink(pvxiPort,
> pdevLink->lid); vxiDisconnectException(pvxiPort,(addr*100 +
> secondary)); pdevLink->lid = 0; pdevLink->connected = FALSE; } } }
> vxiDestroyIrqChannel(pvxiPort); vxiDestroyDevLink(pvxiPort,
> pvxiPort->server.lid); pvxiPort->server.connected = FALSE;
> pvxiPort->server.lid = 0; clnt_destroy(pvxiPort->rpcClient);
> pasynManager->exceptionDisconnect(pvxiPort->pasynUser); return
> asynSuccess; }
> static void vxiReport(void *drvPvt,FILE *fd,int details) {
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
ASYN VXI-11 Eric Norum
Prev: RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Next: Re: CA server bind failure on Windows Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASYN VXI-11 Eric Norum
Next: Problems with vxWorks IOCs on base 3.14.12.6 Mark Rivers
