Hi Ben,
> This might be something not specific to the sequencer; at least I am not
> aware of doing anything special for the clean or uninstall targets.
I only get that error with the sequencer, not with any other modules. It looks like the error is in the documentation directory.
Indeed I get that error by simply running non-parallel make in the documentation directory:
J:\epics\support\seq\documentation>make clean
rm -rf O.Common
process_begin: CreateProcess(NULL, rm -rf O.Common, ...) failed.
make (e=2): The system cannot find the file specified.
Makefile:45: recipe for target 'clean' failed
make: [clean] Error 2 (ignored)
So it looks like there is no O.Common directory there, and that produces an error?
There is indeed no O.Common directory, but make on Linux just silently ignores that.
corvette:~/support/seq/documentation>make clean
rm -rf O.Common
-----Original Message-----
Sent: Saturday, January 14, 2017 1:25 PM
To: Mark Rivers; [email protected]
Subject: Re: Problem with parallel make with seq 2.2.4 on Linux
Am 14.01.2017 um 19:57 schrieb Mark Rivers:
> Hi Ben,
> Thanks for the quick reply.
> I added HDEPENDS_METHOD=MKMF here in src/snc/Makefile:
> # avoid deprecation warnings with base 3.15 and later
> ifeq ($(BASE_3_14),YES)
> LEMON = $(call PATH_FILTER,$(INSTALL_HOST_BIN)/lemon$(HOSTEXE))
> else
> LEMON = $(abspath $(INSTALL_HOST_BIN)/lemon$(HOSTEXE))
> endif
> include $(TOP)/configure/RULES
> That worked to fix the parallel make problems on Linux. Without that
line it was failing about 50% of the time, with it I saw no failures in
over 15 attempts.
Good! I think this is it, then.
> There is a minor problem on Windows, which is independent of the HDEPENDS line:
> J:\epics\support\seq>make -sj8 clean uninstall
> The above error seems to be benign, but it would be nice to eliminate it.
Can you send the full output with -j8 but without -s? If you have make
version >= 4 then you could add the command line flag -Orecurse, which
gives maximally correlated grouping of output for parallel builds,
making it easier to see where exactly the problem appears.
Cheers
Ben
> From: [email protected] [mailto:[email protected]] On Behalf Of Ben Franksen
> Sent: Saturday, January 14, 2017 10:35 AM
> To: [email protected]
> Am 14.01.2017 um 16:52 schrieb Ben Franksen:
>> Anyway, I can suppress the error message with make-3.81/gcc-4.7.2 by
>> adding explicit dependencies of the relevant .d files:
>> lexer.o: snl.h
>> type_check.o: snl.h
>> var_types.o: snl.h
>> The other combination (make-4.1/gcc-5.4.0) is not able to complete
>> successfully when run directly after rm -f snl.h *.d, even with these
>> extra dependencies listed.
> Please ignore the last sentence, I made a mistake. Adding the explicit
> dependencies really does work on my machine, too. But I still think this
> is not the right way to fix the problem. Manually added dependencies are
> brittle in the face of evolving code, which is why we auto-generate them
> in the first place.
> A better fix (I think) is to set
> in src/snc/Makefile (in the CONFIG section). This lets the EPICS build
> system use mkmf.pl to generate the dependencies even on platforms where
> the C compiler supports the appropriate flags to generate dependencies.
> (Note that for 3.14 I had already copied the corresponding rule from
> base-3.15 which is why the problem manifests only with 3.15).
> (I noticed that after I do 'rm snl.h *.d' this still does not
> re-generate the .d files for the three files that include snl.h. It is
> hard for me to judge whether this may cause problems in the future.)
> Anyway, if this works for you (Mark), then I will make a new release
> with this fix (and with a fix for the other build problem you reported).
> Cheers
> Ben
- Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
- Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
- Re: Problem with parallel make with seq 2.2.4 on Linux Andrew Johnson
- RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Re: ASYN VXI-11 Ben Franksen
<2017>
2025
2026
<2017>
2025
2026
