Subject: Re: Problem with parallel make with seq 2.2.4 on Linux
To: Andrew Johnson <[email protected]>, <[email protected]>
Date: Sat, 14 Jan 2017 22:12:57 +0100
Am 14.01.2017 um 16:52 schrieb Ben Franksen:
> The problem is that snl.h is generated *and* that the dependency (.d)
> files generated by make use gcc for this.
> It seems that 'gcc -MM -MF' is not able to cope with not yet existing
> include files.
I have looked at the gcc docs and found this:
-MG
    In conjunction with an option such as -M requesting dependency
generation, -MG assumes missing header files are generated files and
adds them to the dependency list without raising an error. The
dependency filename is taken directly from the #include directive
without prepending any path. -MG also suppresses preprocessed output, as
a missing header file renders this useless.
    This feature is used in automatic updating of makefiles.
It seems to me that this is usually what one wants/expects. So perhaps
the EPICS build rules should use -MG when using gcc to generate .d files?
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Re: Problem with parallel make with seq 2.2.4 on Linux Andrew Johnson
Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
Prev: Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
Next: RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Prev: RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Next: StreamDevice 2.7.7 won't build with Visual Studio 2010 Mark Rivers
