For now what I am doing is hijacking the GNU_DIR variable in my <>/configure/os/CONFIG_SITE.Common.<target> in order to add the environment variable before the compiler.
Ugly but it is working so far.
Hi All,
I would like to set an environment variable to customize or disable CCACHE when building for a specific set of targets. Where would be the correct place to do that? Thank you, Hugo
- Re: Set env var for target when building Johnson, Andrew N.
- Set env var for target when building Hugo Slepicka
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
