Hi Hugo,
You can put export statements in those same CONFIG_SITE.Common.<arch> files, they only get executed when compiling for that specific architecture, i.e.
export VAR = value
which sets VAR in the environment for all commands executed in the O.<arch> directories but won't affect any other architectures.
HTH,
- Andrew
Sent from my iPad
For now what I am doing is hijacking the GNU_DIR variable in my <>/configure/os/CONFIG_SITE.Common.<target> in order to add the environment variable before the compiler.
Ugly but it is working so far.
Hi All,
I would like to set an environment variable to customize or disable CCACHE when building for a specific set of targets.
Where would be the correct place to do that?
Thank you,
Hugo
- Re: Set env var for target when building Hugo Slepicka
- Set env var for target when building Hugo Slepicka
Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
