Subject: Re: Set env var for target when building
To: "Johnson, Andrew N." <[email protected]>
Date: Tue, 17 Jan 2017 16:42:52 +0000
Hi Andrew,
Thank you for your answer!
I will adjust my CONFIG file to use export.
Cheers,
Hugo
On Mon, Jan 16, 2017 at 7:34 PM Johnson, Andrew N. <[email protected]> wrote:
Hi Hugo,
You can put export statements in those same CONFIG_SITE.Common.<arch> files, they only get executed when compiling for that specific architecture, i.e.
    export VAR = value
which sets VAR in the environment for all commands executed in the O.<arch> directories but won't affect any other architectures.
HTH,
- Andrew
Sent from my iPad
On Jan 16, 2017, at 6:59 PM, Hugo Slepicka <[email protected]> wrote:
For now what I am doing is hijacking the GNU_DIR variable in my <>/configure/os/CONFIG_SITE.Common.<target> in order to add the environment variable before the compiler.
Ugly but it is working so far.
On Mon, Jan 16, 2017 at 4:52 PM Hugo Slepicka <[email protected]> wrote:
Hi All,
I would like to set an environment variable to customize or disable CCACHE when building for a specific set of targets.
Where would be the correct place to do that?
Thank you,
Hugo
Set env var for target when building Hugo Slepicka
Re: Set env var for target when building Hugo Slepicka
Re: Set env var for target when building Johnson, Andrew N.
Prev: RE: Knowing if a server application is running Mark Rivers
Next: Re: Knowing if a server application is running Ralph Lange
Prev: Re: Set env var for target when building Johnson, Andrew N.
Next: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
